First of all, thank you for the great work you have done. This was just what I was looking for for quite some time. The only issue I have is that Kodi wonāt install any addons. It comes back with ācanāt connect to the repositoryā Also it wonāt install themes or download cover art. Network settings show up ok in kodi and my piās connectivity is ok too. I would suspect it to be a a permission issue but canāt find anything related to this in the log. The only permission related error is for udisk. Am I overlooking something? My most recent kodi log is attached. 15:27:45.389 T:1946386432 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:27:45.389 T:1946386432 NOTICE: -----------------------------------------------------------------------
15:27:45.389 T:1946386432 NOTICE: Starting Kodi (17.1-RC2 Git:20170312-b2013fd-dirty). Platform: Linux ARM 32-bit
15:27:45.389 T:1946386432 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
15:27:45.389 T:1946386432 NOTICE: Kodi compiled Mar 12 2017 by GCC 4.9.2 for Linux ARM 32-bit version 3.16.7 (200711)
15:27:45.389 T:1946386432 NOTICE: Running on Raspbian GNU/Linux 8 (jessie), kernel: Linux ARM 32-bit version 4.4.9-v7+
15:27:45.389 T:1946386432 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
15:27:45.389 T:1946386432 NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
15:27:45.389 T:1946386432 NOTICE: ARM Features: Neon disabled
15:27:45.390 T:1946386432 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
15:27:45.390 T:1946386432 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
15:27:45.390 T:1946386432 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
15:27:45.390 T:1946386432 NOTICE: special://masterprofile/ is mapped to: /home/kodi/.kodi/userdata
15:27:45.390 T:1946386432 NOTICE: special://envhome/ is mapped to: /home/kodi
15:27:45.390 T:1946386432 NOTICE: special://home/ is mapped to: /home/kodi/.kodi
15:27:45.390 T:1946386432 NOTICE: special://temp/ is mapped to: /home/kodi/.kodi/temp
15:27:45.390 T:1946386432 NOTICE: special://logpath/ is mapped to: /home/kodi/.kodi/temp
15:27:45.390 T:1946386432 NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi.bin
15:27:45.390 T:1946386432 NOTICE: Local hostname: volumio
15:27:45.390 T:1946386432 NOTICE: Log File is located: /home/kodi/.kodi/temp//kodi.log
15:27:45.390 T:1946386432 NOTICE: -----------------------------------------------------------------------
15:27:45.413 T:1946386432 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
15:27:45.493 T:1946386432 NOTICE: load settings...
15:27:45.684 T:1946386432 NOTICE: Found 2 Lists of Devices
15:27:45.684 T:1946386432 NOTICE: Enumerated PI devices:
15:27:45.684 T:1946386432 NOTICE: Device 1
15:27:45.684 T:1946386432 NOTICE: m_deviceName : HDMI
15:27:45.685 T:1946386432 NOTICE: m_displayName : HDMI
15:27:45.685 T:1946386432 NOTICE: m_displayNameExtra:
15:27:45.685 T:1946386432 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
15:27:45.685 T:1946386432 NOTICE: m_channels : FL,FR
15:27:45.685 T:1946386432 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
15:27:45.685 T:1946386432 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
15:27:45.685 T:1946386432 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
15:27:45.685 T:1946386432 NOTICE: Device 2
15:27:45.685 T:1946386432 NOTICE: m_deviceName : Analogue
15:27:45.685 T:1946386432 NOTICE: m_displayName : Analogue
15:27:45.685 T:1946386432 NOTICE: m_deviceType : AE_DEVTYPE_PCM
15:27:45.685 T:1946386432 NOTICE: m_sampleRates : 48000
15:27:45.685 T:1946386432 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
15:27:45.685 T:1946386432 NOTICE: m_streamTypes : No passthrough capabilities
15:27:45.685 T:1946386432 NOTICE: Device 3
15:27:45.686 T:1946386432 NOTICE: m_deviceName : Both
15:27:45.686 T:1946386432 NOTICE: m_displayName : HDMI and Analogue
15:27:45.686 T:1946386432 NOTICE: m_displayNameExtra:
15:27:45.686 T:1946386432 NOTICE: m_deviceType : AE_DEVTYPE_PCM
15:27:45.686 T:1946386432 NOTICE: m_channels : FL,FR
15:27:45.686 T:1946386432 NOTICE: m_sampleRates : 48000
15:27:45.686 T:1946386432 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
15:27:45.686 T:1946386432 NOTICE: m_streamTypes : No passthrough capabilities
15:27:45.686 T:1946386432 NOTICE: Enumerated ALSA devices:
15:27:45.686 T:1946386432 NOTICE: Device 1
15:27:45.686 T:1946386432 NOTICE: m_deviceName : @
15:27:45.686 T:1946386432 NOTICE: m_displayName : Default (bcm2835 ALSA bcm2835 ALSA)
15:27:45.687 T:1946386432 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000
15:27:45.687 T:1946386432 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
15:27:45.687 T:1946386432 NOTICE: m_streamTypes : No passthrough capabilities
15:27:45.717 T:1946386432 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
15:27:45.717 T:1946386432 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<fanartres>720</fanartres>
<imageres>540</imageres>
<video>
<busydialogdelayms>750</busydialogdelayms>
</video>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<cache>
<memorysize>31457280</memorysize>
</cache>
</advancedsettings>
15:27:45.720 T:1946386432 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
15:27:45.720 T:1946386432 NOTICE: Default Video Player: VideoPlayer
15:27:45.720 T:1946386432 NOTICE: Default Audio Player: paplayer
15:27:45.720 T:1946386432 NOTICE: Disabled debug logging due to GUI setting. Level 0.
15:27:45.720 T:1946386432 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
15:27:45.720 T:1946386432 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
15:27:45.723 T:1946386432 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:27:45.725 T:1946386432 NOTICE: Loaded playercorefactory configuration
15:27:45.725 T:1946386432 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:27:45.726 T:1946386432 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
17:27:45.795 T:1946386432 NOTICE: Running database version Addons27
17:27:46.085 T:1946386432 NOTICE: ADDONS: Using repository repository.xbmc.org
17:27:46.249 T:1946386432 ERROR: DBus: Error org.freedesktop.UDisks.Error.PermissionDenied - Not Authorized
17:27:46.315 T:1946386432 NOTICE: Raspberry PI firmware version: Mar 3 2017 13:42:34
Copyright (c) 2012 Broadcom
version 9ae30f71c7ef4239e9d5b56346c0842f3ef56736 (clean) (release)
17:27:46.315 T:1946386432 NOTICE: ARM mem: 752MB GPU mem: 256MB MPG2:0 WVC1:0
17:27:46.315 T:1946386432 NOTICE: cache.memorysize: 30MB libass.cache: 0MB
17:27:46.316 T:1946386432 NOTICE: Config:
arm_freq=1200
audio_pwm_mode=1
config_hdmi_boost=5
core_freq=400
desired_osc_freq=0x36ee80
disable_commandline_tags=2
disable_l2cache=1
disable_splash=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=300
hdmi_force_cec_address=65535
hdmi_force_hotplug=1
init_uart_clock=0x2dc6c00
lcd_framerate=60
over_voltage_avs=0x10c8e
over_voltage_avs_boost=0x10c8e
overscan_bottom=48
overscan_left=48
overscan_right=48
overscan_top=48
pause_burst_frames=1
program_serial_random=1
ramfsaddr=-1
sdram_freq=450
temp_limit=85
device_tree=-
ramfsfile=volumio.initrd
17:27:46.316 T:1946386432 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
17:27:46.319 T:1946386432 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
17:27:46.319 T:1946386432 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
17:27:46.320 T:1946386432 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 60.000000 Hz
17:27:46.320 T:1946386432 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 59.940063 Hz
17:27:46.320 T:1946386432 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 60.000000 Hz
17:27:46.320 T:1946386432 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 59.940063 Hz
17:27:46.320 T:1946386432 NOTICE: Found resolution 1152 x 864 for display 0 with 1152 x 864 @ 75.000000 Hz
17:27:46.320 T:1946386432 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 60.000000 Hz
17:27:46.320 T:1946386432 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 59.940063 Hz
17:27:46.320 T:1946386432 NOTICE: Found resolution 1360 x 768 for display 0 with 1360 x 768 @ 60.000000 Hz
17:27:46.320 T:1946386432 NOTICE: Found resolution 1360 x 768 for display 0 with 1360 x 768 @ 59.940063 Hz
17:27:46.320 T:1946386432 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
17:27:46.320 T:1946386432 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 59.940063 Hz
17:27:46.320 T:1946386432 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
17:27:46.320 T:1946386432 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
17:27:46.320 T:1946386432 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
17:27:46.320 T:1946386432 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz
17:27:46.321 T:1946386432 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
17:27:46.321 T:1946386432 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
17:27:46.321 T:1946386432 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
17:27:46.321 T:1946386432 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
17:27:46.321 T:1946386432 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
17:27:46.321 T:1946386432 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 25.000000 Hz
17:27:46.321 T:1946386432 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 30.000000 Hz
17:27:46.321 T:1946386432 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 29.970032 Hz
17:27:46.321 T:1946386432 NOTICE: Found (1920x1080@60.000000) at 31, setting to RES_DESKTOP at 16
17:27:46.321 T:1946386432 NOTICE: Checking resolution 16
17:27:46.502 T:1946386432 NOTICE: GL_VENDOR = Broadcom
17:27:46.503 T:1946386432 NOTICE: GL_RENDERER = VideoCore IV HW
17:27:46.503 T:1946386432 NOTICE: GL_VERSION = OpenGL ES 2.0
17:27:46.503 T:1946386432 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
17:27:46.503 T:1946386432 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
17:27:47.742 T:1926230960 NOTICE: Running database version Addons27
17:27:47.745 T:1926230960 NOTICE: Running database version ViewModes6
17:27:47.748 T:1926230960 NOTICE: Running database version Textures13
17:27:47.764 T:1818477488 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
17:27:47.765 T:1926230960 NOTICE: Running database version MyMusic60
17:27:47.784 T:1926230960 NOTICE: Running database version MyVideos107
17:27:47.789 T:1926230960 NOTICE: Running database version TV29
17:27:47.792 T:1926230960 NOTICE: Running database version Epg11
17:27:47.797 T:1946386432 NOTICE: start dvd mediatype detection
17:27:47.906 T:1946386432 WARNING: CSkinInfo: failed to load skin settings
17:27:48.575 T:1946386432 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
17:27:49.404 T:1946386432 NOTICE: initialize done
17:27:49.404 T:1946386432 NOTICE: Running the application...
17:27:49.420 T:1946386432 NOTICE: starting zeroconf publishing
17:27:49.422 T:1946386432 NOTICE: CWebServer[8080]: Started
17:27:49.422 T:1946386432 NOTICE: starting upnp client
17:27:49.479 T:1946386432 NOTICE: starting upnp renderer
17:27:49.501 T:1946386432 ERROR: JSONRPC Server: Failed to connect to sdpd
17:27:49.506 T:1623245744 NOTICE: ES: Starting UDP Event server on port 9777
17:27:49.507 T:1623245744 NOTICE: UDP: Listening on port 9777 (ipv6 : true)
17:27:49.598 T:1946386432 NOTICE: VideoPlayer: Opening: :0
17:27:49.598 T:1946386432 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
17:27:49.602 T:1596842928 NOTICE: Creating InputStream
17:27:49.605 T:1596842928 ERROR: CVideoPlayer::OpenInputStream - error opening [:0]
17:27:49.605 T:1596842928 NOTICE: CVideoPlayer::OnExit()
17:27:49.606 T:1946386432 ERROR: Playlist Player: skipping unplayable item: 0, path [:0]
17:27:49.678 T:1946386432 NOTICE: CVideoPlayer::CloseFile()
17:27:49.678 T:1946386432 NOTICE: VideoPlayer: waiting for threads to exit
17:27:49.678 T:1946386432 NOTICE: VideoPlayer: finished waiting
17:27:49.679 T:1946386432 NOTICE: VideoPlayer: Opening: tcp
17:27:49.682 T:1596842928 NOTICE: Creating InputStream
17:27:49.683 T:1596842928 ERROR: CVideoPlayer::OpenInputStream - error opening [tcp]
17:27:49.683 T:1596842928 NOTICE: CVideoPlayer::OnExit()
17:27:49.684 T:1946386432 ERROR: Playlist Player: skipping unplayable item: 1, path [tcp]
17:27:49.737 T:1946386432 NOTICE: CVideoPlayer::CloseFile()
17:27:49.737 T:1946386432 NOTICE: VideoPlayer: waiting for threads to exit
17:27:49.737 T:1946386432 NOTICE: VideoPlayer: finished waiting
17:27:49.737 T:1946386432 NOTICE: VideoPlayer: Opening: vt7
17:27:49.751 T:1596842928 NOTICE: Creating InputStream
17:27:49.752 T:1596842928 ERROR: CVideoPlayer::OpenInputStream - error opening [vt7]
17:27:49.752 T:1596842928 NOTICE: CVideoPlayer::OnExit()
17:27:49.753 T:1946386432 ERROR: Playlist Player: skipping unplayable item: 2, path [vt7]
17:27:50.803 T:1946386432 NOTICE: CVideoPlayer::CloseFile()
17:27:50.804 T:1946386432 NOTICE: VideoPlayer: waiting for threads to exit
17:27:50.804 T:1946386432 NOTICE: VideoPlayer: finished waiting
17:27:50.804 T:1946386432 NOTICE: CVideoPlayer::CloseFile()
17:27:52.338 T:1605231536 WARNING: SetMenuLanguage - TV menu language set to unknown value 'kor'
17:28:18.495 T:1723909040 ERROR: GetDirectory - Error getting
17:30:37.918 T:1749074864 ERROR: Previous line repeats 6 times.
17:30:37.918 T:1749074864 NOTICE: VideoInfoScanner: Starting scan ..
17:31:14.056 T:1749074864 WARNING: No information found for item 'smb://NAS4FREE/Videos/TV Shows/Bears Wild Weekend with Stephen Fry.SD.hannibal.avi', it won't be added to the library.
17:31:14.763 T:1749074864 WARNING: No information found for item 'smb://NAS4FREE/Videos/TV Shows/David.Bowie.and.the.Story.of.Ziggy.Stardust.WS.PDTV.XviD-thebox.Penna.avi', it won't be added to the library.
17:31:24.222 T:1648411568 NOTICE: LoadJpeg: unable to load http://thetvdb.com/banners/actors/345957.jpg
17:31:25.741 T:1648411568 NOTICE: LoadJpeg: unable to load http://thetvdb.com/banners/actors/345958.jpg
17:31:27.238 T:1648411568 NOTICE: LoadJpeg: unable to load http://thetvdb.com/banners/actors/345931.jpg
17:31:30.888 T:1648411568 NOTICE: LoadJpeg: unable to load http://thetvdb.com/banners/actors/392276.jpg
17:31:33.692 T:1648411568 NOTICE: LoadJpeg: unable to load http://thetvdb.com/banners/actors/391776.jpg
17:31:37.108 T:1648411568 NOTICE: LoadJpeg: unable to load http://thetvdb.com/banners/actors/391774.jpg
17:31:39.456 T:1648411568 NOTICE: LoadJpeg: unable to load http://thetvdb.com/banners/actors/391769.jpg
17:31:44.581 T:1648411568 NOTICE: LoadJpeg: unable to load http://thetvdb.com/banners/actors/391768.jpg
17:31:50.650 T:1648411568 NOTICE: LoadJpeg: unable to load http://thetvdb.com/banners/actors/328641.jpg
17:31:54.621 T:1648411568 NOTICE: LoadJpeg: unable to load http://thetvdb.com/banners/actors/328637.jpg
17:31:59.604 T:1648411568 NOTICE: LoadJpeg: unable to load http://thetvdb.com/banners/actors/328634.jpg
17:32:38.390 T:1648411568 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
17:32:38.572 T:1648411568 WARNING: Previous line repeats 1 times.
17:32:38.572 T:1648411568 NOTICE: LoadJpeg: unable to load http://thetvdb.com/banners/posters/71326-8.jpg
17:34:56.275 T:1623245744 NOTICE: ES: Client from ::ffff:192.168.0.14 timed out
17:36:02.934 T:1749074864 WARNING: No information found for item 'smb://NAS4FREE/Videos/TV Shows/Rick.Steins.Spain.S01.DVDRip.XviD-SPRiNTER/', it won't be added to the library.
17:36:03.316 T:1749074864 WARNING: No information found for item 'smb://NAS4FREE/Videos/TV Shows/Stephen Fry's 100 Greatest Gadgets.thebox.hannibal.avi', it won't be added to the library.
17:36:04.113 T:1749074864 WARNING: No information found for item 'smb://NAS4FREE/Videos/TV Shows/Stephen.Fry.Gadget.Man.S01E01.480p.HDTV.x264-mSD.mkv', it won't be added to the library.
17:36:04.824 T:1749074864 WARNING: No information found for item 'smb://NAS4FREE/Videos/TV Shows/stephen.fry.gadget.man.s01e02.hdtv.x264-c4tv.mp4', it won't be added to the library.
17:36:06.229 T:1749074864 WARNING: No information found for item 'smb://NAS4FREE/Videos/TV Shows/Stephen.Fry.Gadget.Man.S01E03.HDTV.XviD-AFG.avi', it won't be added to the library.
17:36:06.824 T:1749074864 WARNING: No information found for item 'smb://NAS4FREE/Videos/TV Shows/Stephen.Fry.Gadget.Man.S01E04.480p.HDTV.x264-mSD.mkv', it won't be added to the library.
17:36:07.588 T:1749074864 WARNING: No information found for item 'smb://NAS4FREE/Videos/TV Shows/Stephen.Fry.Gadget.Man.S01E05.480p.HDTV.x264-mSD.mkv', it won't be added to the library.
17:36:08.877 T:1749074864 WARNING: No information found for item 'smb://NAS4FREE/Videos/TV Shows/The Best - Series 1 - (Spring 2002) [TVRip (XVID)]/', it won't be added to the library.
17:36:09.708 T:1749074864 WARNING: No information found for item 'smb://NAS4FREE/Videos/TV Shows/Untitled Folder/', it won't be added to the library.
17:36:10.367 T:1749074864 WARNING: No information found for item 'smb://NAS4FREE/Videos/TV Shows/Untitled Folder 2/', it won't be added to the library.
17:36:10.954 T:1749074864 WARNING: No information found for item 'smb://NAS4FREE/Videos/TV Shows/WDYTYA_ Stephen Fry.avi', it won't be added to the library.
17:36:11.794 T:1749074864 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 05:33
17:37:46.203 T:1946386432 NOTICE: Samba is idle. Closing the remaining connections
17:38:15.750 T:1749074864 ERROR: GetDirectory - Error getting
17:40:26.264 T:1749074864 ERROR: Previous line repeats 2 times.
17:40:26.264 T:1749074864 ERROR: CCurlFile::FillBuffer - Failed: Couldn't connect to server(7)
17:40:26.264 T:1749074864 ERROR: CCurlFile::Open failed with code 0 for http://mirrors.kodi.tv/addons/krypton/addons.xml.gz.md5
17:40:26.264 T:1749074864 ERROR: Open - failed to open source <http://mirrors.kodi.tv/addons/krypton/addons.xml.gz.md5>
17:40:26.264 T:1749074864 ERROR: CRepository: failed read 'http://mirrors.kodi.tv/addons/krypton/addons.xml.gz.md5'
17:40:30.452 T:1946386432 ERROR: GetDirectory - Error getting addons://repos/
17:40:30.453 T:1946386432 ERROR: CGUIMediaWindow::GetDirectory(addons://repos/) failed
17:41:21.665 T:1792275376 ERROR: OnTvStandby - Unexpected [standby_pc_on_tv_standby] setting value
17:41:58.610 T:1623245744 NOTICE: ES: Client from ::ffff:192.168.0.14 timed out
17:50:08.309 T:1749074864 ERROR: CCurlFile::FillBuffer - Failed: Couldn't connect to server(7)
17:50:08.309 T:1749074864 ERROR: CCurlFile::Open failed with code 0 for http://mirrors.kodi.tv/addons/krypton/addons.xml.gz.md5
17:50:08.309 T:1749074864 ERROR: Open - failed to open source <http://mirrors.kodi.tv/addons/krypton/addons.xml.gz.md5>
17:50:08.310 T:1749074864 ERROR: CRepository: failed read 'http://mirrors.kodi.tv/addons/krypton/addons.xml.gz.md5'
17:50:13.630 T:1946386432 ERROR: GetDirectory - Error getting addons://repos/
17:50:13.631 T:1946386432 ERROR: CGUIMediaWindow::GetDirectory(addons://repos/) failed
17:51:13.909 T:1792275376 ERROR: OnTvStandby - Unexpected [standby_pc_on_tv_standby] setting value
17:52:07.048 T:1623245744 NOTICE: ES: Client from ::ffff:192.168.0.28 timed out
[SOLVED]
I chmodded /home/volumio to 777 and that seems to have done the trick.
Everything is working fine now. Itās not how it should be, I suppose but itās working.
Now I can play with offloading to usb and/or usb boot on my pi 3.
Thanks again for the great work.
All you open source programmers really help a great deal to make this world a better place.
