I like the new grid view for the sources (see 2.246 Changelog changelog-t1575.html). But they look very large for me, particularly on small screens, or on a smartphone. Even on my 13" laptop, I have to scroll down to view the bottom tiles.
Would it be possible to make them smaller? Or better, to adapt their size to the screen, so that we don’t need to scroll or slide?
Thank you!
Hello!
Any idea about this suggestion? Is there any way to reduce the size of the tiles (Favorites, Playlists, Music Library, Artists, …)? Is there a parameter somewhere in the config files? Or in the css?
Thank you for your help!
Sisim
This solution works! change-size-elements-disable-elements-browse-tab-t9053.html
Thanks @andib
