Hi im new here i installed the GPIO Buttons plugin and it dosent work for some reason.
SO i have tried a pull up and a pull down GPIO as toald on the github page … i even have added a 10 k pull down resistor my self but still no luck. i teste my button with a multimeter and it works as expected.
Now if i connect to pin 17 for example and dont do a thing songs get skippt but if i hold in the button nothing happends. Nope the button works the normal way around as i allready sayed.
have you guys any idea? i use a Pi3b
What kind of button are you using, make or break contact?
Seems it’s a break (default closed)
The button closes the circuit on pressing it.
then please share a picture what you have done.
Default drawing is something like this. The GPIO must be set as input:
![image](https://community.volumio.com/uploads/default/original/3X/6/0/60c6152c51b82894ffb60fa2cc517e3c03b3d110.png)
gimme a second. So i need to add a 1 K between the gpio pin as well? i will give this a try . thank you for helping me ![:smiley: :smiley:](https://community.volumio.com/images/emoji/apple/smiley.png?v=10)
to avoid burning the GPIO and make sure you use a GPIO that is configured as input.
well i had no 1k so i used a 2.2 k and a 10 k but still. the song is skipping if i dont press the button. even if i remove the button songs get skippt but if i shorten those two kable it stops skipping like pressing the button does. is there any setting i got to do beside installing the plugin cause thats all i did
And where is your 3.3V connection?
I only see 2 wires connected to the rPi.
![image](https://community.volumio.com/uploads/default/original/3X/2/4/24773efa4f1a01399b5d0948bf0d7c367fe6c9de.png)
but if i connected like you say my 3.3 will be shorten to ground
here is my new try the 2 not connected cables act as my button… still no luck
What do you think the 10K resistor does?
you are right now i did it like you sayed even with the right pins…still same problem . on button press nothing happens and on none connection songs get skipped rappedly
please test other GPIO, you need a default low with the given diagram.
Or you can try to to connect the 10K to the ground and the switch to 3.3V.
Swaped transistors… had them mixed i gues… now it works. i thank you very much for your help
you made my day
Then you lucky, you didn’t fry the rPi.
