GPIO Buttons Not Working
Hi All,
I have a RPI5 4GB with NVME installed with V3.785 and I can’t get the GPIO buttons (plugin 0.8.4) to work. I am using a 10K pull down and can see the voltage on GPIO17 rise from 0V to 3.3V when the momentary switch is pressed. Everything else works perfectly. Today, I have done a clean install just to test the GPIO buttons and it’s the same - no response. Am I doing something wrong or if not is there an alternative. I’d just like to have Play/Pause and Prev/Next tracks as hardware switches.
Thanks in advance.
