Getting Lag while browsing through Albums in Volumio
My Volumio source is a folder I have created on my NAS Drive which has around 1300 albums.
Everytime when I am using Volumio App on my iPad to access the albums and select the tracks, there is a huge lag while browing through the albums in the same folder.
Any thoughts / suggestions as why this might be happening as I keep adding new albums in this same folder to acces it through Volumio while playing songs on Volumio.
Please suggest as what should I do to avoid this lagging and should be able to browse throught the albums freely as due to this I am feeling to get out of Volumio as using Volumio will be no use that too after such a pathetic UI experience.
Thanks & Regards,
Rajiv
Do you get the same lag if you login to volumio.local via the browser on your ipad instead of using the Volumio app?
Just a thought.
Michael
Is it a newish ipad and how’s your wifi? It’s absolutely fine on a recent ipad and terrible on an old one. You can try going to Sources and scroll down to album art size, try something smaller. Finally, in browse mode you can select list view instead of tiles.
No Michael, I do not get the same lag when I login into Volumio.local via the browser on my PC…in fact let me try the browser option on my ipad and share the outcome as I have not tried the browser option on i-pad except taken the app route
its not a very old ipad Simon and the wifi is also good. Let me try the other option you suggested
I find that rebooting my Samsung tablet will speed up accessing volumio on the app
