I am new to Volumio and like it very much. Unfortunately it appears that gapless playback does not work properly or perhaps doesn’t work at all.
I had originally posted this topic in an old thread but didn’t get useful feedback there for some reason, So I hope it is ok that I post it as a new topic.
My hardware: Pi3 B and Hifiberry DAC+.
Software: Volumio 2.378
Use case: I play MP3 files from an USB stick.
The problem is that there are always audible interruptions between the tracks. If I play the same files on the same hardware, but with Rune Audio player, there are no interruptions.
I have added two examples that demonstrate the different behavior of Volumio vs. RuneAudio. I have recorded them directly from the analog audio output of the HifiBerry DAC. The examples are played from the same audio files with the same hardware.
With Volumio there is an obvious interruption at the transition between the tracks, with RuneAudio there is no interruption.
I hope someone can give me some information if I have missed some setting or if this is a bug.
Thank you,
crashpilot
Examples_Gapless.zip (1.59 MB)
