hello
so I tried the equipement, same cable, on a Fedora
[fred@localhost ~]$ uname -a
Linux localhost.localdomain 4.6.3-300.fc24.x86_64 #1 SMP Fri Jun 24 20:52:41 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
it works like a charm…
[ 213.718575] usb 3-1: new full-speed USB device number 2 using ohci-pci
[ 213.927872] usb 3-1: New USB device found, idVendor=040d, idProduct=340b
[ 213.927890] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 213.927899] usb 3-1: Product: FX-AUDIO-D-802
[ 213.927906] usb 3-1: Manufacturer: FX-AUDIO
[ 214.107532] input: FX-AUDIO FX-AUDIO-D-802 as /devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.2/0003:040D:340B.0001/input/input14
[ 214.160210] hid-generic 0003:040D:340B.0001: input,hidraw0: USB HID v1.00 Device [FX-AUDIO FX-AUDIO-D-802] on usb-0000:00:12.0-1/input2
[ 214.390175] usbcore: registered new interface driver snd-usb-audio
I will go on with experiments on the Odroid C2 and Volumio, so some news soon on this thread
thx a lot for your time and help !
Fred
1st Edit: here is the lsusb -t on volumio
volumio@volumio:~$ lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 4: Dev 3, If 0, Class=Vendor Specific Class, Driver=rtl8192cu, 480M
same error shown on dmesg
[88582.690075] usb 1-1.2: new full-speed USB device number 12 using dwc_otg
[88582.849930] ERROR::handle_hc_nak_intr:1307: Can not read device info from hub.We take it error
[88582.862708] usb 1-1.2: can't set config #1, error -71
damned… I will now upgrade to the new test version
