Thx, I will try again. These are my first couple days into the raspberry world. Cheers man.
Seems to work, thanks No more āfailed to open audio outputā error message.
good! Enjoy
How long before FusionDSP will be on V3 released today?
itās in the plugins ā¦
yes, in test mode
did i understand right, if i want to install/use dsp i have to choose a Test Image?
I use an RPI3.
I couldnāt find a dsp Plugin in the Menue.
Sorry dir the inconveniences.
in /dev, click on True in Plugins Test Mode, then go back to plugins page
i was able to install.
I hope i can test the next days.
I read that iām able to input the txt File from REW.
One more Question,
Can i use the txt 1to1, or have i to fix some things in it?
Sorry, my Englisch is a littlebit rusty
And thanks for this great work.
Yes, you can use it directly without modification! Just copy it into the fusiondsp folder (type \volumio in windows explorer) on the raspi and select and load it into the plugin!
Correct! Put files in Fusiondsp/peq from your explorer. And go in the plugin settings, in PEQ mode, load file for each channel
As this point, only peaking is supported, should be fine with Rew.
Last point, I suggest to use v0ā¦1.13 for the plugin. Enable plugin test mode in IP/Dev. Remove previous version, reboot and install new one by clicking ādetailsā and select v0ā¦1.13š
hi i also use a rpi3 and i dont see how to activate a plugin test mode in volumio 3
use volumio.local/dev or 192.168.1.*/dev
Hi there,
itĀ“s running.
I was able to include the REW txt File to Volumio.
I used WinSCP to browse the folders.
The right folder is /data/INTERNAL/FusionDSP/peq/
ItĀ“s shown in the menue from the Fusion DSP too, i saw to late. Sorry.
Thank you
Hi! I have been able to successfully install the v0.1.13, but when using the parametric EQ (manually setting the filters), if I stream to my RP via air play I hear a lot of noise (I realised about it when double checking my EQ settings with REW, and confirmed it playing a fixed tone at 1000Hz). The noise completely disappears when switching off the plugin. I know that it is a very specific problem, but I hope it can be solved. I mainly need the plugin when streaming with air play, otherwise I EQ the music via Roonā¦
You donāt need scp to access the folder. From your computer, in file explorer, you should see it in network. Most of users make things more complicated that needed
Same way to store music on the SD card
Oh, i try this two or three times.
But everytime the WEBUI was opend (i think i kick Windows ) and not the Volumio Explorer.
I will look in the Evening again.
Yesterday my focus was on FusionDSPš, so i choose WinSCP
So i tried fusiondsp again following the golive Volumio 3 on my x86 /usb dac and still no sound. Tried both local files and Radio Paradise and no sound. Including the log below.http://logs.volumio.org/volumio/LuFa3Z3.html
volumio/LuFa3Z3
Yes. I still canāt figure out why no sound in x86 when mod is used.
Spotify connect works with itā¦
