yesterday i had a little workaround with Fusion and REW.
It’s fine.
The import option (make a txt File in REW and copied it to Fusion) makes the setup much easyer.
Will say thanks again.
Flo
It’s fine.
Flo
Hello!
FusionDsp v1.0.18 stable release
Amazing @balbuze!
Hello together
Can I create a crossover with the zones in Multiroom and FusionDsp?
I want to run the satellites in one zone and the subwoofer in another zone. I want the satellites to be separated at 100 HZ and anything below 100 Hz to be reproduced by the subwoofer.
Thanks a lot.
Hello!
Multiroom send untouched signal. So on each device a different Dsp setting can be applied.
On the first device only <100Hz set a Lowpass 100,0.707
Hello balbuze,
thank you for the quick and positive response.
Have a good Sunday
Hello!
FusionDsp v1.0.19 beta
Hej,
I’m having a problem when using fusiondsp together with a homecinema receiver using hdmi. I’m using 5 channels in advanced mode and it works fine. (I’m having an active speaker system playing stereo). But, camilladsp stops and restarts with a new config every time I switch album. I can reload my config with apply but that’s a bit cumbersome…
Br Thomas
Hi!
You have to set FusionDsp on Pure Camilla Gui mode and stay here.
In Camilla Gui, once you have set your values, save your config camilla.yml (or something like that) in the required tab. It should be fine
Edit: see here. How-to FusionDsp - #39 by balbuze
Hello!
FusionDsp v1.0.20 stable
Enjoy
Hello!
FusionDsp v1.0.21 stable
New switches to mute channels
Translation improvements
Added Harman as target curve for FIR creation
Enjoy
I’m having issues with 1.0.21 running on the latest Volumio betas.
So it’s basically unusable for me at the moment but as I updated both Volumio and FusionDSP at the same time, it’s hard to be sure where the problem lies. If I find time, I might install FusionDSP 1.0.20 instead and see if that is working better.
I see. It is because I added new settings and the config file seems to be not updated correctly. 2 ways : remove and reinstall the plugin v1.0.21 or disable the plugin and remove the config
rm /data/configuration/audio_interface/fusiondsp/config.json
Then enable the plugin
In both cases, you lose your settings…
I’ll have a look to see how to fix it.
Sorry for that.
WARNING! I found a bug in FusionDsp v1.0.21 as @Voluminous described.
I’m going to fix it.
The problem occurs after saving and loading a preset.
Please wait for next version…
Sorry for that
FusionDsp v1.0.22 stable
Sorry for inconvenience
Thanks, i updated and still got sound from only the right channel using my preset. So then i decided to explore the “More settings” menu and saw that “left mute” option was selected, although I have never selected this feature. I unselected and applied the setting change (and got sound from both channels again), saved the setting, switched settings, then switched back to test it and the left mute was applied again. Seems that I can’t get rid of it.
Yes, the previous v1.0.21 corrupted the config file.
In your case, to fix
Or remove it and re install
Seems to be working now. Thanks for the quick fix!
you’re welcome
Info : Autoeq updated theirs methods of optimization for Eq. Now it supports Highshelf and Lowshelf filters.
In FusionDsp, to use new calculated Eq with the new algorithm, just reselect your headphones and press ‘load and use’. That’s it
Warning : previous Eq are not available anymore.
More details Post in thread ‘AutoEQ Magic?’ AutoEQ Magic? | Page 4 | Audio Science Review (ASR) Forum
