Just curious, have you every used a parametric EQ? Once you are used to it, you will probably never want to use a graphic EQ again.
Yeah, sure. Personally, graphic EQ is much more intuitive.
Thanks! Any chance for extendable up to 30-bands EQ?
I agree, Parametric EQ is really more precise. You can set precisely frequencies to adjust.
I donāt plan to make a 30 ways graphic Eq.
I canāt tell when I will add Q for graphic Eq as it is a low priority usage, that may be confusing.
I need to think of it. But as I said, itās on Todo list.
Have you ever played with an interactive parametric EQ such as Fabfilter Pro-Q 3? This takes parametric EQ to a whole new level and is very intuitive. I believe you can try it for free for a while. You can also use it to create EQ settings which you can export to other parametric EQ tools such as FusionDSP but you need to multiply the Q settings by 0.707 if you want to convert to the standard which most other apps use. https://www.fabfilter.com
Thanks, mate. Iāve tried a lot of parametric EQs.
BTW, ProQ 3 has very weak functionality and transparency compared to Kirchhoff-eq and many others.
a quick question. When using parametric EQ, where do I set preamp value?
Is it the L+R Gain levels?
The preamp attenuation is calculated and set by the plugin. It uses highest positive value set +2 dB. Ex if you have
Peaking 123,3,1.2
Peaking 234,2,6.3
Peaking 456,-3,3.3
Then attenuation is 3+2=5dB
If only negative values, attenuation is -2dB to avoid potential clipping due to phase rotation.
In an other words, you have nothing to do.
Left and right attenuation are here if you want to add a specific attenuation to a channel.
I have a Pi 4b and using USB to my DACā¦is there any best practices for suggestions on how to eliminate dropouts or studdering? It seems to work ok for a few mins and the it starts to studder. I have the latest of everything.
So I can ignore AutoEQ recommendation regarding the preamp values?
In the Headphone specific section, they state which general preamp values to set. In my case, -6.2db.
Nothing to do⦠This is a bug that should be fixed in a future Volumio and FusionDsp version.
Just choose your headphone from the scrolling list, apply, itās done!
I hope it will be soon. This is coolest plugin, go Volumio team
Donāt understand why it takes so long.
I will help you with 3 hypothesesā¦
1- We like when users are waiting for us
2- Nothing is done
3- We are working hard to fix it, but it is something really not easy
Choose oneā¦
Eug I will choose Blue.
- Linear time doesnāt exist, all Volumio releases already exist.
Do you actually realise how much free time this guy (yes, balbuze is an unpaid volunteer) uses to give you a plugin you can use for free? Seems a bunch of ungrateful people we have nowadays.
Really helps motivating us, volunteers (not).
Hey I donāt mean it offensive. Iām also software developer and every time customer ask me why this function takes so long they canāt understand it lol. Relax.
I would help balbuze but my territory is React web development and CRUD services hehe.
In that case I really donāt understand your reaction, your customers are paying you and have an excuse, you donāt!
But, letās leave it with that, think you got the pointā¦
