All:
For those looking for test tracks to test the filter settings:
https://www.focal.com/en/focal-teach/cd-focal-tools
Thanks, balbuze. You’re a star :pray:.
v 0.1.17 works with Tidal Connect, Spotify Connect and local files on RPi 2B+ with NAD D3020 USB and RPi 3A with RME ADI DAC
Hi everyone.
Well I’m new with volumio… I need your help please.
I have Pi4 with Hifiberry dac+, I installed the fusion dsp and at soon I activate the plugin the sound goes off with error Failed to open ā€œALSA defaultā€ (alsa);
Can anyone give me some advice please?
Thanks.
volumio@volumio:~$ aplay -l
card 0: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 1: sndrpihifiberry [snd_rpi_hifiberry_dacplus], device 0: HiFiBerry DAC+ HiFi pcm512x-hifi-0 [HiFiBerry DAC+ HiFi pcm512x-hifi-0]
Subdevices: 0/1
card 7: Dummy [Dummy], device 0: Dummy PCM [Dummy PCM]
Subdevices: 0/1
Please, send log : Sending logs for troubleshooting - Volumio Documentation
http://logs.volumio.org/volumio/2PaE8Rr.html
Log you sent is very hard to use because full of useless messages…
Good usage is to reboot, reproduce the problem and send log.
But I saw peppyalsa is installed… This plugin is unsupported…
If you want to test FusionDsp, disable eppyalsa :wink:
http://logs.volumio.org/volumio/MO9i8Hg.html
The screen saver is not a problem for me… I like to test the Fusion
one more thing, with FusionDsp enabled, can you send ?:
/data/configuration/audio_interface/fusiondsp/camilladsp.yml
thanks
How I do that???
ah, not familliar with ssh and linux?
try to play something and change something in Eq. Resend log
Did you reboot after enable FusionDsp ?
http://logs.volumio.org/volumio/SyMGgr1.html
Yes I have reboot… At soon I click play I get the error…
I really need
enable ssh SSH - Volumio Documentation
and
cat /data/configuration/audio_interface/fusiondsp/camilladsp.yml > /data/INTERNAL/clog.yml
Then copy past this fiile from the Volumio shared folder, see bottom of this page
https://volumio.github.io/docs/FAQs/Audio_Sources.html
devices:
  samplerate: 44100
  chunksize: 1024
  silence_threshold: -60
  silence_timeout: 3.0
  queuelimit: 1
  target_level: 1024
  adjust_period: 3
  capture:
    type: File
    channels: 2
    format: S32LE
    filename: "/dev/stdin"
    extra_samples: 4096
  playback:
    type: Alsa
    channels: 2
    device: "postDsp"
    format: S32LE
filters:
  nulleq2:
    type: Conv
  eq1:
    type: Biquad
    parameters:
      type: Peaking
      freq: 25
      q: 1.85
      gain: 1.5
  eq2:
    type: Biquad
    parameters:
      type: Peaking
      freq: 40
      q: 1.85
      gain: 2.5
  eq3:
    type: Biquad
    parameters:
      type: Peaking
      freq: 63
      q: 1.85
      gain: 1.5
  eq4:
    type: Biquad
    parameters:
      type: Peaking
      freq: 100
      q: 1.85
      gain: 1
  eq5:
    type: Biquad
    parameters:
      type: Peaking
      freq: 160
      q: 1.85
      gain: 0.5
  eq6:
    type: Biquad
    parameters:
      type: Peaking
      freq: 250
      q: 1.85
      gain: 0
  eq7:
    type: Biquad
    parameters:
      type: Peaking
      freq: 400
      q: 1.85
      gain: 0
  eq8:
    type: Biquad
    parameters:
      type: Peaking
      freq: 630
      q: 1.85
      gain: -0.5
  eq9:
    type: Biquad
    parameters:
      type: Peaking
      freq: 1000
      q: 1.85
      gain: 0
  eq10:
    type: Biquad
    parameters:
      type: Peaking
      freq: 1600
      q: 1.85
      gain: 0.5
  eq11:
    type: Biquad
    parameters:
      type: Peaking
      freq: 2500
      q: 1.85
      gain: 1
  eq12:
    type: Biquad
    parameters:
      type: Peaking
      freq: 4000
      q: 1.85
      gain: 1.5
  eq13:
    type: Biquad
    parameters:
      type: Peaking
      freq: 6300
      q: 1.85
      gain: 3
  eq14:
    type: Biquad
    parameters:
      type: Peaking
      freq: 10000
      q: 1.85
      gain: 4
  eq15:
    type: Biquad
    parameters:
      type: Peaking
      freq: 16000
      q: 1.85
      gain: 1.5
mixers:
  stereo:
    channels:
      in: 2
      out: 2
    mapping:
      - dest: 0
        sources:
          - channel: 0
            gain: -6
            inverted: false
      - dest: 1
        sources:
          - channel: 1
            gain: -6
            inverted: false
pipeline:
  - type: Mixer
  - type: Filter
    channel: 0
    names:
      - eq1
      - eq2
      - eq3
      - eq4
      - eq5
      - eq6
      - eq7
      - eq8
      - eq9
      - eq10
      - eq11
      - eq12
      - eq13
      - eq14
      - eq15
  - type: Filter
    channel: 1
    names:
      - eq1
      - eq2
      - eq3
      - eq4
      - eq5
      - eq6
      - eq7
      - eq8
      - eq9
      - eq10
      - eq11
      - eq12
      - eq13
      - eq14
      - eq15
Fine…
I try to do my best. I’m sorry for the troubles, keep learning.
Thanks again for your help.
The error shows
Failed to open ā€œalsaā€ (alsa); Failed to open ALSA device ā€œvolumioā€: No such device or address
Thanks! Perfect.
The only problem is that I don’t know why it returns that…
If this the case, disable resampling in volumio
resampling in volumio is disable.
Still get the error.
You believe I should start again from scratch? I mean to make a fresh installation?
Oh yes! Please
Ok. I let you know ASAP :slight_smile:
@ balbuze
OK… Fresh installation all is working perfect. Perfect sound.
Thank you for your help.
Hello! Merry Christmas!
New version with automatic delay calculation.
v0.1.18
Enter Left and right speaker absolute or relative distance from listening point, and delay is set!
:wink:
Edit. Remove previous version, reboot and install the new version. All settings for the plugin are lost…
