FreeBSD Support
Hi!
I was wondering how hard would it be to convert the volumio project to x86 based FreeBSD Linux. I think it shouldn’t be too complicated.
The reason I’m asking is because I have this powerful FreeNAS machine that can easily handle all my DSD convertion, indexing, it is always on and just works great, so I’m thinking - why do I even deal with Raspberry PI? My box can easily function as a Plex Media Server with real-time transcoding, so audio should be really easy.
FreeNAS has a concept of plugins running in jails (kind of like Docker containers), so volumio can be added as a first-class plugin right next to other plugins like Crashplan, Transmission, Plex, SickRage, CouchPotato and many more.
Thanks!
To be honest, that would be a massive undertaking and furthermore is out of the scope of the project… Sorry
Ok, thank you.
To be clear - it is a Linux based OS that has MPD built in. Running in a jail means you can do whatever you want in that partition.
But I understand there are priorities.
Thanks!
Just to be clear - freeBSD is not Linux in any way.
en.wikipedia.org/wiki/FreeBSD#Background
but to help, on freeNAS you can run a virtual machine of any type - so you could use the Volumio Audiophile Music Player for PC (X86/X64) .img file and run it as a vm on freeNAS
doc.freenas.org/11/vms.html
cheers
