The Focusrite Scarlett 2i2 USB DAC works just fine with Volumio. I have used this DAC on Cubox-i 4Pro and Raspberry Pi. It has excellent performance, 24-bit / up to 96 KHz. From MPD Configuration choose “USB” and it just works.
Can I ask you what is your complete setup? I just tried with Raspberry Pi, Wifi dongle and Focusrite Scarlett 2i2.
I make some tests with Dlna server and Flac in Ram disk but same results, sometimes I hear the little discontinous in the music and I don’t understand what’s the reason.
Sorry for my poor english
Same here, can’t work @24/96 like as pc
I have the 2i4. Anyone used one of these with a Pi? I’m gearing up to build a Volumio system. Trying to decide what DAC I want…
I used it.
Can’t be able to set at 24/96 on volumio 1.55
Setup:
Odroid-C2
Volumio2: RC2Fix Released: Sun 31 Jul 12:55:31 CEST 2016
USB HDD
Focusrite 2i2 DAC with Headphone Amp
up to 24-bit @ 192kHz
Output is clear and has no unusual behavior. There are no dropouts.
Can anybody confirm Scarlett 2i2 2nd Gen with latest firmware works OK or not?
Thanks.
I tested
SteamOS
Debian
Fedora
Ubuntu
Volumio
the same result everywhere.
The Scarlett Focusrite is recognized as USB device. You can select it as output device.
But there is no sound.
Anybody can help?
