Added some new folders to library and got the same problem - found out that cause was damaged FLAC file (incomplete download). After removing it scan completed normally. I had similar issues with Windows payers that manage libraries. It would be great if Volumio was able to skip damaged files, but this problem is not so significant - we can work around it adding to library in portions to find problematic file.
