Hi there, it would be awesome if we could use fixed ip for volumio devices (for these with static ip) in app so it wouldn’t search for them every single time (or have an option to add them manually)
Hey @gTc,
Are you reporting problem here with manual IP setup? What is your observation here, what is the actual problem?
Unless… Have you checked in the UI Network at all?
and switch Automatic IP to user defined?
I believe OP means a way to add device with static address to the application, which it would instantly show on launch before network discovery.
What I would do is to cache the devices found on each app launch, then instantly check if those devices answer on next app launch, before doing the network discovery.
This is exactly what I ment
Hi all,
an input field in the Volumio APP would be great.
The target IP address or full DNS Name of the Volumio device.
As an example with access via VPN to my home network, my playing device is in a different IP subnet as the Volumio device.
Now the Volumio APP cannot find my Volumio device.
The Volumio APP is only browsing within it’s own IP subnet, which is not enough for routed IP network setups.
with APP, I mean, android or IOS app.
kind regards
Messing around with my home lab, I have now also ran into this issue. I can surf my various instances of Volumio on different subnets via PC but not on the Android app, which only sees the Volumio instance on the same subnet. So this is definitely not a firewall issue on the networking side.
