Ok first time here. I have got the sd card in with Volumio on it into Raspberry Pi 3. I dont have ethernet available. I have it hooked hdmi to a monitor. Powered up and on the screen it reads
Raspbian GNU/Linux 8 volumio ttyl
volumio login:
Not sure what to do now.
What I am trying to do is have it attached to an external hd w/flac files and also a usb dac going to my stereo. Want to play music etc.
ok I hooked the rasberry into router via ethernet and then went to volumio.local. I am setting up the audio output. How can I set it to an USB Dac? It says Do you have an is2Dac which I dont and then the only other option is Audio jack. No option for my HRT II Streamer USB Dac. Stuck again. Help!
Wanted a dedicated music server. I use the same laptop for work etc. Also less CPU noise. Etc. Still having issues with this thing. Not able to connect now… Ugh.
Starting to think you are right here. Having issues w/Volumio and 2 tb of music. It is failing. Luckily it all was a cheap experiment and still kinda cool.
