I have searched but cannot find where file type and spec compatibility is listed. I have had trouble with wav files for instance. They are not recognized within Volumio. Thank you
Hi leisureman,
you should be fine with wav (as long as the files are ok). You can check exactly what filetypes are supported by mpd (& hence Volumio) by typing the following at the command line:
mpd --version
Edit: Or even look here more simply
