File transfer over home wifi
I have Volumio installed on a Raspberry Pi 2B, which connects via USB wifi dongle.
It is located in an inconvenient position, so to add files to the storage usb I add the Pi as a network location in Windows 10, then can move files with ease.
Then I updated to Windows 11, and when I try “Add a network location” with the IP I get “Windows requires a share to publish to. Please try another location”
I must stress that Volumio works perfectly, from this laptop, any browser, phone apps etc. no problems. My phone can see the Pi in ES file explorer, and move files, but I want to do it from my laptop.
Any ideas?
open Windows Explorer and try:
file://<ip-address of your pi>
This brings up “cannot find, check spelling and try again”
Further messing with Add Network Location,
\\USB brings up an Enter Network Credentials box with username already in, a space for password and them, in red “You can’t access this shared folder b/c your orgs security policies block unauthenticated guest access…”
error
Company laptop with Groups policies?
Firewall?
As the above mentioned method works on every Windows 11 PC I have (4 different ones)
Not a company laptop, just an oldish thinkpad I upgraded to 11.
Not too hot on firewalls and permissions, but i think thats where I need to be looking.
Cannot connect from laptop with SSH using Putty either.
My other Pi, runs Plexmediaserver, I can share to it, ssh no problems only difference is connection via cable not wifi (although I can’t access it from my phone??)
is your wired and Wifi connecting using the same network mask 255.255.255.0?
So both WiFi and Wired runs for example on 192.168.1.xxx
As far as I can tell, yes.
Then I run out of ideas
Thank you anyway.
On Windows 11 24H2 I use a UNC path in File Explorer (as I used to do in Windows 10)
In the address bar \\volumio
Then I can choose the music folder
I use a script to back up the volumio music drive to an external USB drive on my PC too, for that I map a drive letter and then release it after the backup completes.
net use v: \\volumio\usb\music
backup stuff here
net use v: /delete
\volumio does nothing
\Kitchensounds gets me this far…
Hey @Mick_Poor,
From you screenshot: Are you certain that you are using with your player correct log-on details
  • username: volumio
  • password: volumio
Correct?
No, I have changed username and password.
I have just booted my win11 laptop with a Linux Mint usb stick, opened the file manager, went to Network, and accessed both rpi’s, volumio and plex, once I entered creds…
Must be a windows issue.
Please have a look here, as I said before it seems a policy issue::
https://answers.microsoft.com/en-us/windowsclient/forum/all/im-receiving-an-error-when-trying-to-connect-to-a/8650bc9f-bf25-4dde-99cd-25e617f1ae67
Bingo! not quite sure how but that did it, many thanks.
A follow-up to this.
I was running Windows 11 24H2 Home Edition and everything was working OK.
Some time since this question was asked and solved, I found that I had a similar situation, an update or two happened mid-week this week just gone.
Using a UNC path in File Explorer I was suddenly prompted for a username and password (these were saved and working ages ago). Network error 1208 was the result using the correct username and password.
Testing using net use to map a drive also failed, “A system error 3227320323 has occurred.”
A bit of digging around found that the ability to connect to non-signed shares was disabled, and that it could be fixed by using gpedit.
Windows 11 Home doesn’t have gpedit. So an alternate method is to use a registry edit.
To allow insecure outgoing connections, open Regedit and go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\LanmanWorkstation\Parameters.
Create a new DWORD, name it RequireSecuritySignature and set its value to 0.
Testing after this change showed both ‘net use’, for drive mapping, and accessing shares via a UNC path is now working again.
Hopefully this helps others who have Windows 11 24H2 with updates breaking the CIFS connections to Volumio.
Open file explorer, right click on network , click map network drive … in the folder put \192.168.23\usb
The ip of your volumio would be the address of course , then boom! Your in… it will put a folder in this pc that you can read and write into…
Hope this helps.
That had been working, as noted above. But a recent security change in Windows 11 (turning off access to un-signed shares as the default) broke it.
\\xxx.xxx.xxx.xxx\ stopped working, as did \\hostname\
