I have a folder with two mp4 files. Volumio sees and plays the smaller file, but doesn’t see or play the larger file. The smaller file is 3.3GB, the larger 5.1GB. Have I run into a size constraint? If not, I’ll try to rip the DVD again. I’d like to hear the full opera, not just the first half.
What is the format of the medium with the files on? (Fat32 has a 4GB file limit, but I didn’t think you’d be able to write the larger file to it).
Is the file integrity ok, can you play it with different software?
Don’t I feel foolish. The file is toast. Time to go back to the DVD and try to figure out what I did a year ago.
No worries, it happens to everyone. Main thing is that you’re sorted.
