I just did a clean install of 2.348 on a RPI 3 with a windows 10 box and from what I could tell everything went fine except I can’t open Volumio to load media in file explorer.
What am I missing, or should I try to reinstall?
Many thanks
Rich
Many thanks
Rich
Can you give us a bit more detail about what exactly you are trying to do … are you trying to access the spare space on your sd card??
Thanks chsims
Yes, I want to be able to add music files to the SD card over the WiFi network for volumio to play.
UPDATE: I just rebooted both systems and Volumio showed up on the network as a accessible node.
I may have to take on another project if I want a challenge
