Field notes: sourcing cheap secondhand Japanese hi-fi (DACs, amps, headphones) for a Volumio rig
I’ve been feeding a Volumio/Pi front end from a stack of secondhand Japanese gear for a while, so here are a few field notes in case they help anyone building on a budget.
Japan’s domestic used market is the cheapest place I know to buy hi-fi — gear turns over fast and tends to get graded honestly. Three channels I actually use:
  • Hard-Off / recycle chains — the “junk” corner is where DACs, headphone amps and old integrated amps end up for a few thousand yen. “Junk” (ジャンク) usually means untested, not broken, but budget for the occasional dud.
  • Yahoo! Auctions Japan & Mercari JP — by far the deepest selection for used TEAC / Denon / Marantz / Fostex / Audio-Technica, but both are domestic-only: they won’t ship overseas and most sellers won’t touch a foreign card or address.
  • Local recycle shops for cables, cheap DACs and the odd Topping/SMSL board.
That domestic-only wall is the real catch. What worked for me is a proxy/forwarding service that gives you a Japanese address, buys on your behalf, and consolidates several wins into one parcel so you’re not paying EMS three times over. I’ve been using OneMall for the consolidation — you can search the Japanese listings in English or Japanese and it pulls Yahoo Auctions / Mercari results:
Caveats I learned the hard way: check voltage (Japan is 100V — most solid-state gear is fine, but tube amps want a step-up transformer), and factor customs + forwarding into the “cheap” price before you get excited. For a Pi/Volumio setup, a used JP DAC plus a cheap headphone amp still lands well under a new equivalent.
Anyone else sourcing from Japan — what have you scored?
