Wasn’t sure if I should post here or in the DACs section…
The Fe-Pi Audio V1 (https://fe-pi.com/products/fe-pi-audio-v1) board is not listed in the DAC section of this forum, but is selectable from the settings section of the Volumio UI as an I2S output. However, I can’t get it to work. I can get output to work with either the Pi headphone jack or using a NuForce USB DAC. I am able to ssh into the pi and use speaker-test to get output via the RCA jacks on the Fe-Pi. Any clues on how I can get this working?
Pi Board: Raspberry Pi 3 Model B V1.2
Fe-Pi board: Fe-Pi Audio V1.5
Volumio image: volumio-2.729-2020-03-18-pi.img
Thanks!
-Rob
