Favorite tracklist from Qobuz unresponsive when selecting different tracks- confusing interface
So I am on the trial period, and the Qobuz favorite track list in Volumio is so buggy and laggy as to be unusable and quite frustrating. Why is it so convoluted? There are two different track lists it seems. One is COMPLETELY and UNACCEPTABLY UNRESPONSIVE!!! GRRRR! Yes I’m quite mad about this. Audirvana does not exhibit this issue at all! The OTHER tracklist works!! What gives? Why are there two different track-lists and it seems the one that is responsive and works is the one that can only be accessed from the NOW PLAYING screen on the bottom left, or is it the bottom right area? Ugghhhh… Very unacceptable,
this behavior it’s not normal of course
did you try to uninstall the plugins and see if something changes?
another tips could be trying with the factory reset (from system menu)
If the issue persists please raise a support ticket HERE
Thank you
Davide
VOLUMIO TECH SUPPORT
