I am having trouble scanning a music flac library but its stops at a certain point. I am guessing it has something to do with an illegal object, which it cannot read/process.
I am kind of new, tried to pinpoint the problem myself, but am stuck because I don’t understand where it goes wrong.
It says, it cannot read property ‘0’ or something, but it doesn’t tell me which folder or anything and “events.js:126:13” is kind of cryptic for me…
Nov 20 10:30:05 volumio-rpi2 volumio[808]: error: message=Cannot read property '0' of undefined, stack=TypeError: Cannot read property '0' of undefined
Nov 20 10:30:05 volumio-rpi2 volumio[808]: at /volumio/app/plugins/music_service/upnp_browser/index.js:83:67
Nov 20 10:30:05 volumio-rpi2 volumio[808]: at /volumio/app/plugins/music_service/upnp_browser/index.js:626:21
Nov 20 10:30:05 volumio-rpi2 volumio[808]: at Parser. (/volumio/node_modules/xml2js/lib/parser.js:303:18)
Nov 20 10:30:05 volumio-rpi2 volumio[808]: at emitOne (events.js:116:13)
Nov 20 10:30:05 volumio-rpi2 volumio[808]: at Parser.emit (events.js:211:7)
Nov 20 10:30:05 volumio-rpi2 volumio[808]: at SAXParser.onclosetag (/volumio/node_modules/xml2js/lib/parser.js:261:26)
Nov 20 10:30:05 volumio-rpi2 volumio[808]: at emit (/volumio/node_modules/sax/lib/sax.js:624:35)
Nov 20 10:30:05 volumio-rpi2 volumio[808]: at emitNode (/volumio/node_modules/sax/lib/sax.js:629:5)
Nov 20 10:30:05 volumio-rpi2 volumio[808]: at closeTag (/volumio/node_modules/sax/lib/sax.js:889:7)
Nov 20 10:30:05 volumio-rpi2 volumio[808]: at SAXParser.write (/volumio/node_modules/sax/lib/sax.js:1436:13)
Nov 20 10:30:05 volumio-rpi2 volumio[808]: at Parser.exports.Parser.Parser.parseString (/volumio/node_modules/xml2js/lib/parser.js:322:31)
Nov 20 10:30:05 volumio-rpi2 volumio[808]: at Parser.parseString (/volumio/node_modules/xml2js/lib/parser.js:5:59)
Nov 20 10:30:05 volumio-rpi2 volumio[808]: at /volumio/app/plugins/music_service/upnp_browser/index.js:625:24
Nov 20 10:30:05 volumio-rpi2 volumio[808]: at Request.handleRequestResponse [as _callback] (/volumio/node_modules/unirest/index.js:463:26)
Nov 20 10:30:05 volumio-rpi2 volumio[808]: at Request.self.callback (/volumio/node_modules/unirest/node_modules/request/request.js:187:22)
Nov 20 10:30:05 volumio-rpi2 volumio[808]: at emitTwo (events.js:126:13)
This error in the logs aren’t from the library scanning, but from the upnp browser
specifically:
var services = data.root.device[0].serviceList[0].service;
Thanks for your reply! It did scan other folders before it started to hang.
I have now built my library by adding one folder one at a time and executed an update of the library after that. I found out there was a certain folder which caused the scanning to hang. I was hoping that the error log could tell me with which folder it had problems with scanning.
Anyway, I left out the folder which caused the hanging of the scanning process and is the library is ok.
