same behaviour: more than 7 days offtime every coldboot with error
Volumio-3.703-2024-06-04-pi
Sun Jun 23 19:05:35 CEST 2024
Description="'No info available'"
# cat /proc/version ---------------
Linux version 6.1.77-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1730 SMP Thu Feb 8 15:22:02 GMT 2024
# cat /etc/os-release ---------------
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
VOLUMIO_BUILD_VERSION="4b122b2365bb8c09786cd63b50d1ea6db780eb4e"
VOLUMIO_FE_VERSION="e7cae168f9927391640a091813b8a9656b6909b6"
VOLUMIO_FE3_VERSION="df82a8f23c90a3617c15c55572c8aaea90d8b32a"
VOLUMIO_BE_VERSION="49f98390f2d84c6549f33dc85b694fbd99e4c720"
VOLUMIO_ARCH="arm"
VOLUMIO_VARIANT="volumio"
VOLUMIO_TEST="FALSE"
VOLUMIO_BUILD_DATE="Tue 04 Jun 2024 08:41:12 PM CEST"
VOLUMIO_VERSION="3.703"
VOLUMIO_HARDWARE="pi"
VOLUMIO_DEVICENAME="Raspberry Pi"
VOLUMIO_HASH="8e78a6e3f56f1bcbbd1760812129a8e9"
# ifconfig ---------------
eth0: flags=4163 mtu 1500
inet 192.168.178.53 netmask 255.255.255.0 broadcast 192.168.178.255
ether dc:a6:32:3e:38:05 txqueuelen 1000 (Ethernet)
RX packets 10056 bytes 8668474 (8.2 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 7659 bytes 1414986 (1.3 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73 mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
loop txqueuelen 1000 (Local Loopback)
RX packets 9057 bytes 1576486 (1.5 MiB)
TX packets 9057 bytes 1576486 (1.5 MiB)
wlan0: flags=4163 mtu 1500
inet 192.168.211.1 netmask 255.255.255.0 broadcast 192.168.211.255
ether dc:a6:32:3e:38:06 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 82 bytes 14199 (13.8 KiB)
# sudo iwconfig ---------------
lo no wireless extensions.
eth0 no wireless extensions.
wlan0 IEEE 802.11 Mode:Master Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:off
# aplay -l ---------------
card 0: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 1: sndrpihifiberry [snd_rpi_hifiberry_digi], device 0: HiFiBerry Digi+ Pro HiFi wm8804-spdif-0 [HiFiBerry Digi+ Pro HiFi wm8804-spdif-0]
Subdevices: 1/1
# lsusb ---------------
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
# lsusb -t ---------------
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
# lsusb -v ---------------
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 3
bMaxPacketSize0 9
idVendor 0x1d6b Linux Foundation
idProduct 0x0003 3.0 root hub
bcdDevice 6.01
iManufacturer 3
iProduct 2
iSerial 1
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x001f
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
bMaxBurst 0
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x2109 VIA Labs, Inc.
idProduct 0x3431 Hub
bcdDevice 4.20
iManufacturer 0
iProduct 1
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
idProduct 0x0002 2.0 root hub
bcdDevice 6.01
iManufacturer 3
iProduct 2
iSerial 1
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
# ps -ef ---------------
UID PID PPID C STIME TTY TIME CMD
root 1 0 0 18:54 ? 00:00:05 /sbin/init splash nodebug
root 2 0 0 18:54 ? 00:00:00 [kthreadd]
root 3 2 0 18:54 ? 00:00:00 [rcu_gp]
root 4 2 0 18:54 ? 00:00:00 [rcu_par_gp]
root 5 2 0 18:54 ? 00:00:00 [slub_flushwq]
root 6 2 0 18:54 ? 00:00:00 [netns]
root 7 2 0 18:54 ? 00:00:00 [kworker/0:0-mm_percpu_wq]
root 10 2 0 18:54 ? 00:00:00 [mm_percpu_wq]
root 11 2 0 18:54 ? 00:00:00 [rcu_tasks_rude_kthread]
root 12 2 0 18:54 ? 00:00:00 [rcu_tasks_trace_kthread]
root 13 2 0 18:54 ? 00:00:00 [ksoftirqd/0]
root 14 2 0 18:54 ? 00:00:00 [rcu_sched]
root 15 2 0 18:54 ? 00:00:00 [migration/0]
root 16 2 0 18:54 ? 00:00:00 [cpuhp/0]
root 17 2 0 18:54 ? 00:00:00 [cpuhp/1]
root 18 2 0 18:54 ? 00:00:00 [migration/1]
root 19 2 0 18:54 ? 00:00:00 [ksoftirqd/1]
root 22 2 0 18:54 ? 00:00:00 [cpuhp/2]
root 23 2 0 18:54 ? 00:00:00 [migration/2]
root 24 2 0 18:54 ? 00:00:00 [ksoftirqd/2]
root 27 2 0 18:54 ? 00:00:00 [cpuhp/3]
root 28 2 0 18:54 ? 00:00:00 [migration/3]
root 29 2 0 18:54 ? 00:00:00 [ksoftirqd/3]
root 32 2 0 18:54 ? 00:00:00 [kdevtmpfs]
root 33 2 0 18:54 ? 00:00:00 [inet_frag_wq]
root 35 2 0 18:54 ? 00:00:00 [kauditd]
root 36 2 0 18:54 ? 00:00:00 [khungtaskd]
root 38 2 0 18:54 ? 00:00:00 [oom_reaper]
root 39 2 0 18:54 ? 00:00:00 [writeback]
root 40 2 0 18:54 ? 00:00:00 [kcompactd0]
root 41 2 0 18:54 ? 00:00:00 [kintegrityd]
root 42 2 0 18:54 ? 00:00:00 [kblockd]
root 43 2 0 18:54 ? 00:00:00 [blkcg_punt_bio]
root 44 2 0 18:54 ? 00:00:00 [watchdogd]
root 47 2 0 18:54 ? 00:00:00 [kworker/3:1-events_power_efficient]
root 48 2 0 18:54 ? 00:00:00 [kworker/3:1H-kblockd]
root 49 2 0 18:54 ? 00:00:00 [rpciod]
root 50 2 0 18:54 ? 00:00:00 [xprtiod]
root 51 2 0 18:54 ? 00:00:00 [kworker/u8:3-loop0]
root 53 2 0 18:54 ? 00:00:00 [kswapd0]
root 54 2 0 18:54 ? 00:00:00 [nfsiod]
root 55 2 0 18:54 ? 00:00:00 [kthrotld]
root 57 2 0 18:54 ? 00:00:00 [kworker/2:2-events]
root 60 2 0 18:54 ? 00:00:00 [kworker/2:3-events_freezable]
root 61 2 0 18:54 ? 00:00:00 [hwrng]
root 62 2 0 18:54 ? 00:00:00 [iscsi_conn_clea]
root 63 2 0 18:54 ? 00:00:00 [nvme-wq]
root 64 2 0 18:54 ? 00:00:00 [nvme-reset-wq]
root 65 2 0 18:54 ? 00:00:00 [nvme-delete-wq]
root 67 2 0 18:54 ? 00:00:00 [DWC Notificatio]
root 68 2 0 18:54 ? 00:00:00 [uas]
root 69 2 0 18:54 ? 00:00:00 [vchiq-slot/0]
root 70 2 0 18:54 ? 00:00:00 [vchiq-recy/0]
root 71 2 0 18:54 ? 00:00:00 [vchiq-sync/0]
root 72 2 0 18:54 ? 00:00:00 [zswap-shrink]
root 73 2 0 18:54 ? 00:00:00 [kworker/u9:0-brcmf_wq/mmc1:0001:1]
root 96 2 0 18:54 ? 00:00:00 [sdhci]
root 97 2 0 18:54 ? 00:00:00 [irq/52-mmc0]
root 108 2 0 18:54 ? 00:00:00 [mmc_complete]
root 109 2 0 18:54 ? 00:00:00 [kworker/0:1H-mmc_complete]
root 122 2 0 18:54 ? 00:00:00 [kworker/1:1H-kblockd]
root 126 2 0 18:54 ? 00:00:00 [kworker/2:1H-kblockd]
root 139 2 0 18:54 ? 00:00:00 [kworker/0:2H-kblockd]
root 145 2 0 18:54 ? 00:00:00 [kworker/3:2H-kblockd]
root 149 2 0 18:54 ? 00:00:00 [kworker/1:2H-kblockd]
root 215 2 0 18:54 ? 00:00:00 [jbd2/mmcblk0p2-8]
root 216 2 0 18:54 ? 00:00:00 [ext4-rsv-conver]
root 234 2 0 18:54 ? 00:00:00 [kworker/2:2H-kblockd]
root 252 2 0 18:54 ? 00:00:00 [jbd2/mmcblk0p3-8]
root 253 2 0 18:54 ? 00:00:00 [ext4-rsv-conver]
root 287 2 0 18:54 ? 00:00:00 [mld]
root 288 2 0 18:54 ? 00:00:00 [ipv6_addrconf]
root 316 1 0 18:54 ? 00:00:01 /lib/systemd/systemd-journald
root 336 2 0 18:54 ? 00:00:00 [kworker/1:6-events]
root 338 2 0 18:54 ? 00:00:00 [kworker/1:8-mm_percpu_wq]
root 349 1 0 18:54 ? 00:00:00 /lib/systemd/systemd-udevd
root 371 2 0 18:54 ? 00:00:00 [vchiq-keep/0]
root 372 2 0 18:54 ? 00:00:00 [SMIO]
root 380 2 0 18:54 ? 00:00:00 [mmal-vchiq]
root 382 2 0 18:54 ? 00:00:00 [mmal-vchiq]
root 383 2 0 18:54 ? 00:00:00 [irq/53-feb10000.codec]
root 384 2 0 18:54 ? 00:00:00 [mmal-vchiq]
root 385 2 0 18:54 ? 00:00:00 [mmal-vchiq]
root 386 2 0 18:54 ? 00:00:00 [mmal-vchiq]
root 387 2 0 18:54 ? 00:00:00 [mmal-vchiq]
root 388 2 0 18:54 ? 00:00:00 [mmal-vchiq]
root 441 2 0 18:54 ? 00:00:00 [cfg80211]
root 447 2 0 18:54 ? 00:00:00 [brcmf_wq/mmc1:0]
root 449 2 0 18:54 ? 00:00:00 [brcmf_wdog/mmc1:0001:1]
root 490 2 0 18:54 ? 00:00:00 [kworker/u9:3-hci0]
root 560 1 0 18:54 ? 00:00:02 /usr/sbin/haveged --Foreground --verbose=1 -w 1024
_rpc 573 1 0 18:54 ? 00:00:00 /sbin/rpcbind -f -w
message+ 608 1 0 18:54 ? 00:00:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
volumio 615 1 0 18:54 ? 00:00:00 /usr/local/bin/volumio-remote-updater
nobody 617 1 0 18:54 ? 00:00:00 /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody --deviceglob /dev/input/event*
root 618 1 0 18:54 ? 00:00:00 /usr/sbin/alsactl -E HOME=/run/alsa -s -n 19 -c rdaemon
avahi 624 1 0 18:54 ? 00:00:00 avahi-daemon: running [volumio.local]
root 625 1 0 18:54 ? 00:00:00 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
root 626 1 0 18:54 ? 00:00:00 /bin/bash /bin/volumiologrotate
root 629 1 0 18:54 ? 00:00:00 /lib/systemd/systemd-logind
avahi 675 624 0 18:55 ? 00:00:00 avahi-daemon: chroot helper
root 694 2 0 18:55 ? 00:00:00 [kworker/u8:4-events_unbound]
root 713 1 0 18:55 ? 00:00:00 /usr/lib/bluetooth/bluetoothd --noplugin=sap
root 715 1 0 18:55 ? 00:00:00 /usr/sbin/nmbd --foreground --no-process-group
root 755 1 0 18:55 ? 00:00:00 /usr/sbin/ifplugd -i eth0 -q -f -u0 -d10 -w -I
root 757 2 0 18:55 ? 00:00:00 [kworker/0:5-events]
root 769 1 0 18:55 ? 00:00:00 /usr/sbin/sshd -D
ntp 770 1 0 18:55 ? 00:00:00 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 103:103
root 783 715 0 18:55 ? 00:00:00 /usr/sbin/nmbd --foreground --no-process-group
dnsmasq 852 1 0 18:55 ? 00:00:00 /usr/sbin/dnsmasq -x /run/dnsmasq/dnsmasq.pid -u dnsmasq -7 /etc/dnsmasq.d,.dpkg-dist,.dpkg-old,.dpkg-new --local-service
root 858 1 0 18:55 ? 00:00:00 /usr/sbin/hostapd -B -P /run/hostapd.pid -B /etc/hostapd/hostapd.conf
volumio 861 1 2 18:55 ? 00:00:14 /usr/bin/node /volumio/index.js
root 878 1 0 18:55 ? 00:00:00 /usr/sbin/winbindd --foreground --no-process-group
root 881 878 0 18:55 ? 00:00:00 winbindd: domain child [VOLUMIO]
root 883 1 0 18:55 ? 00:00:00 /usr/sbin/smbd --foreground --no-process-group
root 885 883 0 18:55 ? 00:00:00 /usr/sbin/smbd --foreground --no-process-group
root 886 883 0 18:55 ? 00:00:00 /usr/sbin/smbd --foreground --no-process-group
root 887 878 0 18:55 ? 00:00:00 winbindd: idmap child
root 888 878 0 18:55 ? 00:00:00 winbindd: domain child [BUILTIN]
root 889 883 0 18:55 ? 00:00:00 /usr/sbin/smbd --foreground --no-process-group
root 913 1 0 18:55 ? 00:00:00 /sbin/dhcpcd eth0
volumio 965 861 0 18:55 ? 00:00:00 /usr/bin/node /volumio/app/plugins/miscellanea/albumart/serverStartup.js 3001 /data/albumart
volumio 972 965 0 18:55 ? 00:00:01 /usr/bin/node /volumio/app/plugins/miscellanea/albumart/serverStartup.js 3001 /data/albumart
volumio 973 965 0 18:55 ? 00:00:01 /usr/bin/node /volumio/app/plugins/miscellanea/albumart/serverStartup.js 3001 /data/albumart
volumio 974 965 0 18:55 ? 00:00:01 /usr/bin/node /volumio/app/plugins/miscellanea/albumart/serverStartup.js 3001 /data/albumart
mpd 1065 1 0 18:55 ? 00:00:06 /usr/bin/mpd --systemd
shairpo+ 1132 1 0 18:55 ? 00:00:00 /usr/bin/shairport-sync --configfile=/tmp/shairport-sync.conf
volumio 1149 1 0 18:55 ? 00:00:00 /usr/bin/upmpdcli -c /tmp/upmpdcli.conf
volumio 1165 861 0 18:55 ? 00:00:00 /usr/bin/node /myvolumio/plugins/music_service/streaming_services/streamingProxy.js
root 1504 2 0 19:00 ? 00:00:00 [kworker/3:0-events_power_efficient]
root 1601 2 0 19:00 ? 00:00:00 [kworker/0:1-events]
root 1782 2 0 19:01 ? 00:00:00 [kworker/u8:0]
root 2076 2 0 19:03 ? 00:00:00 [kworker/0:0H]
root 2317 626 0 19:05 ? 00:00:00 sleep 60
root 2318 2 0 19:05 ? 00:00:00 [kworker/2:0]
root 2319 2 0 19:05 ? 00:00:00 [kworker/3:2-events_power_efficient]
root 2322 2 0 19:05 ? 00:00:00 [kworker/2:0H]
volumio 2338 861 0 19:05 ? 00:00:00 /bin/sh -c /usr/bin/node /volumio/logsubmit.js 'No info available'
volumio 2339 2338 0 19:05 ? 00:00:00 /usr/bin/node /volumio/logsubmit.js No info available
volumio 2367 2339 0 19:05 ? 00:00:00 /bin/sh -c ps -ef >>/tmp/logondemand 2>&1
volumio 2368 2367 0 19:05 ? 00:00:00 ps -ef
# df -h ---------------
Filesystem Size Used Avail Use% Mounted on
udev 396M 0 396M 0% /dev
tmpfs 88M 9.0M 79M 11% /run
/dev/mmcblk0p2 2.5G 544M 1.8G 24% /imgpart
/dev/loop0 479M 479M 0 100% /static
overlay 12G 274M 11G 3% /
tmpfs 436M 0 436M 0% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 436M 0 436M 0% /sys/fs/cgroup
tmpfs 20M 28K 20M 1% /var/log
tmpfs 436M 60K 436M 1% /tmp
tmpfs 436M 0 436M 0% /var/spool/cups
tmpfs 436M 0 436M 0% /var/spool/cups/tmp
/dev/mmcblk0p1 91M 66M 25M 73% /boot
# mount ---------------
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=404812k,nr_inodes=101203,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=89156k,mode=755)
/dev/mmcblk0p2 on /imgpart type ext4 (rw,relatime)
/dev/loop0 on /static type squashfs (ro,relatime,errors=continue)
overlay on / type overlay (rw,relatime,lowerdir=/mnt/static,upperdir=/mnt/ext/dyn,workdir=/mnt/ext/work)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,noexec)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup2 on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=38,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
mqueue on /dev/mqueue type mqueue (rw,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
configfs on /sys/kernel/config type configfs (rw,relatime)
sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
tmpfs on /var/log type tmpfs (rw,nodev,relatime,size=20480k,mode=777,uid=1000,gid=4)
tmpfs on /tmp type tmpfs (rw,noatime,mode=755)
tmpfs on /var/spool/cups type tmpfs (rw,noatime,mode=755)
tmpfs on /var/spool/cups/tmp type tmpfs (rw,noatime,mode=755)
/dev/mmcblk0p1 on /boot type vfat (rw,nosuid,nodev,noexec,relatime,fmask=0111,dmask=0000,allow_utime=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro,user)
# netstat -natp ---------------
(Not all processes could be identified, non-owned process info
will not be shown, you would have to be root to see it all.)
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:49152 0.0.0.0:* LISTEN 1149/upmpdcli
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:49149 0.0.0.0:* LISTEN 1149/upmpdcli
tcp 0 0 0.0.0.0:5000 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN -
tcp 0 0 192.168.178.53:55284 31.12.71.119:80 ESTABLISHED -
tcp 0 0 127.0.0.1:40514 127.0.0.1:3000 ESTABLISHED 861/node
tcp 0 0 192.168.178.53:46788 185.246.152.205:8010 TIME_WAIT -
tcp 0 0 127.0.0.1:43800 127.0.0.1:6600 ESTABLISHED 861/node
tcp 0 0 127.0.0.1:60908 127.0.0.1:3000 ESTABLISHED 615/volumio-remote-
tcp 0 0 127.0.0.1:49614 127.0.0.1:6600 ESTABLISHED 861/node
tcp 0 0 127.0.0.1:60912 127.0.0.1:3000 ESTABLISHED 861/node
tcp 0 0 192.168.178.53:47760 35.190.39.113:443 ESTABLISHED 861/node
tcp 0 0 127.0.0.1:47436 127.0.0.1:6599 TIME_WAIT -
tcp 0 0 127.0.0.1:41386 127.0.0.1:6599 ESTABLISHED 1149/upmpdcli
tcp 0 0 127.0.0.1:60950 127.0.0.1:3000 ESTABLISHED 861/node
tcp 0 0 127.0.0.1:60928 127.0.0.1:6600 ESTABLISHED 861/node
tcp 0 0 127.0.0.1:40220 127.0.0.1:6599 ESTABLISHED 1149/upmpdcli
tcp6 0 0 :::139 :::* LISTEN -
tcp6 0 0 :::3245 :::* LISTEN 1165/node
tcp6 0 0 :::111 :::* LISTEN -
tcp6 0 0 :::22 :::* LISTEN -
tcp6 0 0 :::53 :::* LISTEN -
tcp6 0 0 :::6599 :::* LISTEN 861/node
tcp6 0 0 :::6600 :::* LISTEN -
tcp6 0 0 :::5000 :::* LISTEN -
tcp6 0 0 :::3000 :::* LISTEN 861/node
tcp6 0 0 :::3001 :::* LISTEN 965/node
tcp6 0 0 :::3005 :::* LISTEN 861/node
tcp6 0 0 :::445 :::* LISTEN -
tcp6 0 0 127.0.0.1:6599 127.0.0.1:41386 ESTABLISHED 861/node
tcp6 0 0 127.0.0.1:6599 127.0.0.1:40220 ESTABLISHED 861/node
tcp6 0 0 127.0.0.1:3000 127.0.0.1:60950 ESTABLISHED 861/node
tcp6 0 0 192.168.178.53:3000 192.168.178.24:41762 TIME_WAIT -
tcp6 0 0 127.0.0.1:3000 127.0.0.1:60912 ESTABLISHED 861/node
tcp6 0 0 127.0.0.1:3000 127.0.0.1:60908 ESTABLISHED 861/node
tcp6 0 0 192.168.178.53:3000 192.168.178.24:51898 ESTABLISHED 861/node
tcp6 0 0 127.0.0.1:6600 127.0.0.1:43800 ESTABLISHED -
tcp6 0 0 127.0.0.1:6600 127.0.0.1:60928 ESTABLISHED -
tcp6 0 0 192.168.178.53:3000 192.168.178.24:33072 TIME_WAIT -
tcp6 0 0 192.168.178.53:3000 192.168.178.24:58308 ESTABLISHED 861/node
tcp6 0 0 127.0.0.1:6600 127.0.0.1:49614 ESTABLISHED -
tcp6 0 0 192.168.178.53:3000 192.168.178.24:33080 TIME_WAIT -
tcp6 0 0 127.0.0.1:3000 127.0.0.1:40514 ESTABLISHED 861/node
# cat /boot/config.txt ---------------
### DO NOT EDIT THIS FILE ###
initramfs volumio.initrd
gpu_mem=128
gpu_mem_256=32
gpu_mem_512=32
gpu_mem_1024=128
max_usb_current=1
[pi5]
usb_max_current_enable=1
[all]
include volumioconfig.txt
include userconfig.txt
dtoverlay=hifiberry-digi-pro
# cat /boot/userconfig.txt ---------------
# cat /etc/asound.conf ---------------
pcm.!default {
type empty
slave.pcm "volumio"
pcm.volumio {
type empty
slave.pcm "volumioOutput"
# There is always a plug before the hardware to be safe
pcm.volumioOutput {
type plug
slave.pcm "volumioHw"
pcm.volumioHw {
type hw
card "sndrpihifiberry"
# cat /var/log/mpd.log ---------------
Jun 23 11:39 : zeroconf: No global port, disabling zeroconf
Jun 23 11:39 : exception: No such directory
Jun 23 18:59 : exception: No such playlist
Jun 23 19:00 : player: played "http://ct5.fast-serv.com:9844/;"
Jun 23 19:00 : exception: No such playlist
Jun 23 19:01 : player: played "http://ct5.fast-serv.com:9844/;"
Jun 23 19:01 : exception: No such playlist
Jun 23 19:02 : player: played "http://ct5.fast-serv.com:9844/;"
Jun 23 19:02 : exception: No such playlist
Jun 23 19:03 : player: played "http://s39.myradiostream.com:11590/"
Jun 23 19:03 : exception: No such playlist
Jun 23 19:04 : player: played "https://quincy.torontocast.com:2100/"
Jun 23 19:04 : player: played "http://195.201.25.194:8000/"
Jun 23 19:04 : exception: Failed to decode http://listen.shoutcast.com/industrialebmstation; got HTTP status 404
Jun 23 19:04 : player: played "http://listen.shoutcast.com/industrialebmstation"
Jun 23 19:05 : player: played "http://87.106.138.241:8000"
Jun 23 19:05 : exception: Failed to decode https://radio.skynet-local.net:8010/mainchannel.mp3; CURL failed: server certificate verification failed. CAfile: none CRLfile: none
Jun 23 19:05 : player: played "https://radio.skynet-local.net:8010/mainchannel.mp3"
# cat /tmp/camilladsp.log ---------------
cat: /tmp/camilladsp.log: No such file or directory
# cat /tmp/cec-client.log ---------------
cat: /tmp/cec-client.log: No such file or directory
# volumio plugin list ---------------
This command will list installed plugins on your device
----------------------- Installed Plugins:
prettyName: 'Touch Display',
category: 'user_interface',
version: '3.4.0',
icon: 'fa-hand-pointer-o',
isManuallyInstalled: false,
enabled: true,
active: false
# cat /data/configuration/plugins.json ---------------
"music_service": {
"airplay_emulation": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"inputs": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"mpd": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"webradio": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"example_plugin": {
"enabled": {
"type": "boolean",
"value": false
"status": {
"type": "string",
"value": "STOPPED"
"last_100": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"upnp_browser": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"streaming_services": {
"status": {
"type": "string",
"value": "STARTED"
"audio_interface": {
"outputs": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"upnp": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"alsa_controller": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"miscellanea": {
"alarm-clock": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"albumart": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"appearance": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"wizard": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"my_music": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"user_interface": {
"websocket": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"mpdemulation": {
"enabled": {
"type": "boolean",
"value": false
"status": {
"type": "string",
"value": "STARTED"
"rest_api": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"touch_display": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "FAILED"
"system_controller": {
"updater_comm": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"network": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"networkfs": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"services": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"system": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"i2s_dacs": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"volumiodiscovery": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"volumio_command_line_client": {
"enabled": {
"type": "boolean",
"value": true
"status": {
"type": "string",
"value": "STARTED"
"my_volumio": {
"status": {
"type": "string",
"value": "STARTED"
# cat /etc/mpd.conf ---------------
# Volumio MPD Configuration File
# Files and directories #######################################################
music_directory "/var/lib/mpd/music"
playlist_directory "/var/lib/mpd/playlists"
db_file "/var/lib/mpd/tag_cache"
log_file "/var/log/mpd.log"
#pid_file "/var/run/mpd/pid"
#state_file "/var/lib/mpd/state"
#sticker_file "/var/lib/mpd/sticker.sql"
# General music daemon options ################################################
user "mpd"
group "audio"
bind_to_address "any"
#port "6600"
log_level "default"
#save_absolute_paths_in_playlists "no"
#metadata_to_use "artist,album,title,track,name,genre,date,composer,performer,disc"
auto_update "no"
#auto_update_depth "3"
# Symbolic link behavior ######################################################
follow_outside_symlinks "yes"
follow_inside_symlinks "yes"
# Input #######################################################################
input {
plugin "curl"
# proxy "proxy.isp.com:8080"
# proxy_user "user"
# proxy_password "password"
# Decoder ################################################################
decoder {
plugin "faad"
enabled "no"
# Audio Output ################################################################
resampler {
plugin "soxr"
quality "high"
threads "1"
audio_output {
type "alsa"
name "alsa"
device "volumio"
dop "no"
audio_output {
type "fifo"
enabled "no"
name "multiroom"
path "/tmp/snapfifo"
format "44100:16:2"
#replaygain "album"
#replaygain_preamp "0"
volume_normalization "no"
# MPD Internal Buffering ######################################################
audio_buffer_size "2048"
# Resource Limitations ########################################################
#connection_timeout "60"
max_connections "20"
max_playlist_length "81920"
max_command_list_size "81920"
max_output_buffer_size "81920"
# Character Encoding ##########################################################
filesystem_charset "UTF-8"
# volumio endpointstest ---------------
TESTING REMOTE ENDPOINTS
https://google.com, 393 ms: OK
https://www.googleapis.com, 285 ms: OK
https://securetoken.googleapis.com, 310 ms: OK
https://myvolumio.firebaseio.com, 415 ms: OK
https://functions.volumio.cloud, 550 ms: OK
https://oauth-performer.dfs.volumio.org, 261 ms: OK
https://browsing-performer.dfs.volumio.org, 3402 ms: OK
http://cddb.volumio.org, 532 ms: OK
https://functions.volumio.cloud, 1631 ms: OK
http://pushupdates.volumio.org, 276 ms: OK
http://plugins.volumio.org, 814 ms: OK
https://database.volumio.cloud, 1383 ms: OK
https://radio-directory.firebaseapp.com, 342 ms: OK
REMOTE ENDPOINTS TEST OK, all Endpoints are reachable
