Hello
I keep getting this error, I have to shut off and on my Dac every time I use Volumio, it will last a few hours and then I hear a static noise and music stops
Hello
Can someone please look in to this problem, I’m getting this error every hour it’s getting really annoying.
If you need more information let me know
Here is the log :
Starting Live Log…
process exited with code nullinfo: CoreCommandRouter::volumioPushState
info: ------------------------------ 53ms
info: Killing previous LiveLog session
info: Live Log process terminated: null
info: CALLMETHOD: system_controller system setTestSystem false
info: CoreCommandRouter::executeOnPlugin: system , setTestSystem
{ Error: Command failed: rm /data/test
rm: cannot remove ‘/data/test’: No such file or directory
at ChildProcess.exithandler (child_process.js:275:12)
at emitTwo (events.js:126:13)
at ChildProcess.emit (events.js:214:7)
at maybeClose (internal/child_process.js:925:16)
at Socket.stream.socket.on (internal/child_process.js:346:11)
at emitOne (events.js:116:13)
at Socket.emit (events.js:211:7)
at Pipe._handle.close [as _onclose] (net.js:567:12) killed: false, code: 1, signal: null, cmd: ‘rm /data/test’ }
info: Cannot delete test file: Error: Command failed: rm /data/test
RTW: recv_decache: tid=1 seq=2681 frag=0
RTW: recv eapol packet
wlan0: WPA: Group rekeying completed with 80:2a:a8:9a:e2:8a [GTK=CCMP]
RTW: cfg80211_rtw_add_key(wlan0) cipher=0xfac04
RTW: cfg80211_rtw_add_key(wlan0) key_len=16, key_index=2
RTW: cfg80211_rtw_add_key(wlan0) pairwise=0
RTW: cfg80211_rtw_add_key(wlan0) seq_len:6, seq:0x0
RTW: rtw_cfg80211_set_encryption
RTW: rtw_cfg80211_set_encryption(wlan0) set CCMP GTK idx:2, len:16
RTW: ==> rtw_set_key algorithm(4),keyid(2),key_mask(0)
RTW: rtw_cfg80211_set_encryption, ret=0
RTW: set group key camid:5, addr:80:2a:a8:9a:e2:8a, kid:2, type:AES
RTW: send eapol packet
info: CorePlayQueue::getQueue
info: CoreCommandRouter::executeOnPlugin: system , getHwuuid
RTW: OnAction_back
RTW: OnAction_back, action=2
RTW: OnAction_back(): DELBA: 0(27)
usb 1-1.2: USB disconnect, device number 14
info:
---------------------------- USB Audio Device Detached
info: CoreCommandRouter::executeOnPlugin: alsa_controller , usbAudioDetach
info: CoreCommandRouter::executeOnPlugin: i2s_dacs , getI2sStatus
xcb_connection_has_error() returned true
info: CoreCommandRouter::executeOnPlugin: raat , onStop
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
info: CorePlayQueue::getTrack 105
info: CorePlayQueue::getTrack 106
info: Prefetching next song
info: [1612637201579] ControllerTidal::prefetch
MQA
info: Getting stream with soundQuality HI_RES
RTW: rtw_issue_addbareq_cmd, p=0
RTW: BA_starting_seqctrl = 1289 for TID=0
RTW: issue_addba_req(wlan0) ra=80:2a:a8:9a:e2:8a tid=0
RTW: OnAction_back
RTW: OnAction_back, action=1
RTW: agg_enable for TID=0
info: Listing playlists
info: CoreCommandRouter::executeOnPlugin: wizard , getShowWizard
info: CoreCommandRouter::executeOnPlugin: system , getShowWizard
RTW: rtw_issue_addbareq_cmd, p=1
RTW: BA_starting_seqctrl = 424 for TID=1
RTW: issue_addba_req(wlan0) ra=80:2a:a8:9a:e2:8a tid=1
info:
---------------------------- MPD announces system playlist update
RTW: OnAction_back
RTW: agg_enable for TID=1
info: Ignoring MPD Status Update
info: CoreStateMachine::setConsumeUpdateService mpd
info: ------------------------------ 3ms
info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioToken
info: CoreStateMachine::startPlaybackTimer
RTW: OnAction_back
RTW: OnAction_back
