Since january 2024 I’m facing problems with Volumio on Hifiberry 2HD with the re-occuring message “failed to open Alsa”. I followed all steps posted on the forum
writing new SD card
switched to headphones / Saved / switched to Hifiberry 2HD
pulled out the power supply numerous times
switched to factory settings
But I keep on getting this message, and I’m not able to play my music through this Volumio nor listen to a radio station through this Volumio.
Is there anyone who might have the same problem and found a solution for it ? Thanks in advance !
