ucakar
1
When I was upgrading Volumio from version 2,619 I always on all upgrades:
2.632, 2.657, 2.668, 2.672, 2.692. - I always get same Error: Failed to open Alsa device hw:1,0
My Raspberry Pi4 does not recognise Allo Katana anymore…?
But when I donwgrade back to version 2,619 - everything works fine…?
Can please anybody help me?
Thanks in advance.
Andrej
ucakar
2
I have same problem. Can you send me 2.619 version
ucakar
4
Here is the link of 2,619:
updates.volumio.org/pi/volumio/2 … pi.img.zip
Any help would be really appreciated:
Thanks,
Andrej
I don’t have your setup but I found this post on the Moode Audio forums.
I wonder if it will work after running the following in Volumio terminal:
rmmod snd_soc_allo_katana_codec
rmmod snd_soc_audio_graph_card
modprobe snd_soc_audio_graph_card
modprobe snd_soc_allo_katana_codec
Best regards,
Patrick
ucakar
6
[quote=“patrickkfkan”]
Hi Patrick,
When I use all commands manually from terminal, than everything works OK ![:slight_smile: :slight_smile:](/images/emoji/apple/slight_smile.png?v=9)
But when I paste all commands to /etc/rc.local
than is same error.
Is there something else that I miss?
Thanks,
Andrej
Hi Andrej,
Can you try this?
- Create a file called allo-blacklist.conf in the /etc/modprobe.d/ directory (the file can be some other name if you wish, ending with .conf)
sudo touch /etc/modprobe.d/allo-blacklist.conf
sudo nano /etc/modprobe.d/allo-blacklist.conf
In this file, add the following line:
blacklist snd_soc_allo_katana_codec
- Then, edit the file /etc/modules
sudo nano /etc/modules
In this file, add the following two lines:
- Save and reboot
Since I don’t have the hardware for testing, I cannot guarantee this will work, but worth a shot I guess.
-Patrick
ucakar
8
Hi Patrick, thanks for really fast response. I will try in an hour and reply.
Thanks!!!
ucakar
9
Hi Patrick, unfortunatelly on 2.699 version does not work - obviously I am stuck with 2,619 version???
Is it possible someone to fix in next upgrades, please…?
I think I am not alone???
Regards,
Andrej
ucakar
10
Is there still no update to fix that error???
Today I installed the new version 2.713 and still same problem???!!!
When I manually connect via ssh and run command than is starts working???
command in terminal:
Can somebody please help???
ucakar
11
I am stuck at 2.619 version, can you please resolve this bug in later updates???
balbuze
12
please do NOT post 4 times the same problem!
ucakar
13
Yes, sorry, but am I the only owner of Allo Katana??
Can somebody help me with this problem?
Thx,
Andrej
