Fail to open radio stream and usb media disapear
I am running Volumio 2.175.
Since the upgrade to this version my Pi setup has been unstable. The typical problem happens the following way:
  • I go to My Webradio where i created my radios
  • Select one
  • For some reason it fails, maybe bandwidth or else
  • Then go to Music Library and its empty
  • I cannot play anything anymore
USB storage disappear and a reboot is required. I feel there may be a problem handling failed Webradio connections.
Let me know if you want more info.
Else Volumio is fantastic, couldn’t have dreamed better system combined with Piano dac.
Thanks!
Sebatien
