Fail to decode DTS in WAV format
I’m new to Volumio, like the neat UI especially support of cue, however, latest version VERSION: 2.526 fail to decode DTS music ripped in WAV format. (Didn’t test previous version). The same music files can be decoded by Moodeaudio, I suspect it’s a bug in MPD which Volumio deploys with a different version and decoder cfg to Moodeaudio.
Could someone help to fix in next release?
Thanks,
Eric
I’m having the same issue with a number of albums that are .wav files encoded with dts. I’m playing through HDMI connected to a Sony amplifier (STRD A 5400ES) using the latest build (volumio-2.599-2019-08-02-pi.img).
I have used the same Pi with MoOde recently which seems to work ok on most if not all the same files. Obviously, I prefer to use Volumio hence this note.
I’d appreciate any information on this (if it is an) issue and how one can correct it.
Many thanks.
I have same problem. :frowning:
I have same problem with hdmi and dts wav file. I heard only rumor. There’s no news?
Playing DTS files with Volumio. Try this:
Install the Squeezelite plugin and activate it. Use a cheap USB DAC which has optical/coax output.
Set Audio output to this DAC and connect SPDIF to the amplifier. On mine Yamaha ysp-5600 it works. Also PCM files works. Probably also this will work: https://www.amazon.nl/SMSL-PO100-Pro-MQA-DDC/dp/B0BM4D9Q9Q/?_encoding=UTF8&pd_rd_w=kkzIs&content-id=amzn1.sym.4ffae96f-3646-4ed2-84ce-b33055437b2b%3Aamzn1.symc.9556efd4-e363-43c4-82ba-62279bb2c460&pf_rd_p=4ffae96f-3646-4ed2-84ce-b33055437b2b&pf_rd_r=T9K0JJ0P72HEQV4N278R&pd_rd_wg=PNWwe&pd_rd_r=f7a85898-2e37-4880-b01e-89b256c290a0&ref_=pd_hp_d_atf_ci_mcx_mr_ca_hp_atf_d
Now you can also play MQA encoded streams.
Serious bumping a 5 year old topic?
