Factory reset in Rivo plus
After upgrading to version 4.185 I can’t listen to most of my library because it’s 24-bit and now the Rivo+ can’t convert 24.
While waiting for a new version, is it possible to revert to the previous one with a factory reset ? I read that it’s possible to use the recommended file for the Primo (http://repo.volumio.org/Primo/factory_reset), by loading it onto a USB stick, because it works for all models; is this correct ?
A post was merged into an existing topic: Volumio 4 for Volumio products (Motivo, Integro, Primo 2, Primo Plus, Rivo, Rivo Plus)
