I successfully installed Volumio on an SD card and I have an external USB Stick with some music that I want Volumio to add the Music folders in the Music Library. BUT Volumio is not seeing any USB stick (I tried with 4 different sticks/hdd).
The USB is correctly mounted on the raspberry (dmesg tells me that is correctly read) and in /var/lib/mpd/music/USBI can see thestorage` folder (name of my USB with the music):
volumio@volumio:~$ ls /var/lib/mpd/music/USB
storage
I tried the same USB formatted in ext4 and FAT but with always the same result.
Every time I plugged the USB I went to Volumio and I clicked on both rescan and update library. Nothing there.
seems that Music Library doesnât show in the right order i would advice a re-install
but do this after your free myvolumio, i think you could lose the free trail.
normal if you press on music library you see no items , did you scan for the usb already?
system / sources you can update or rescan after this it should show up.
i think there is something wrong in the system after reinstall it should be oke again
is this after a update to 2.882 or fresh install?
my version only shows iconâs so system or setting i could not read that one any more
what pi do you use? p0 p1 p2 p3 p4 / gb?
what are your skills can you manual install plugins?
otherwise you could try a 3.xx version maybe that works better for youâŚ
wait. I reinstall Volumio from scrath, always the same version an in the meanwhile I formatted completely (by erasing all the data) the external Hard Drive. Now it is seeing it!
I formatted the external HDD as FAT32 while the USB stick is ext4 (but I read it shouldnât give troubles).
Tried also to reboot and the hdd is still here seems solved but what could have happened? Does Volumio require some HDD or USB formats (like FAT32 or whatever?)
i think that something went wrong in the install normal it shows no items if itâs empty.
and it didnât do that with yours. and if it shows now it went well if you want to use it on a pc
i would pick fat32 windows doesnât support ext4
