External dac with Primo
Any one know if possible to if possible to use usb out on Primo v2 and connect to smsl su- 9 pro.
Cant find any list info its possible
yes, it is possible
@Darmur thanks
Do you know or had tried to connect both volumio/volumio primo with usb to smsl and tv to smsl optical input
If there some problems when switch from usb to optical on the dac. Will the volumio primo player app/browser need to be put on usb setting.
Was thinking if volumio lose the setting memory
Volumio won’t lose its settings if you switch the DAC input from USB to optical, you should be good to go
