Hi there,
i like the Volumio Playlists and want to use it in another environment.
But i can’t fint m3u or pls file on the volumio partition.
Where to get them in a nice playlist format for a minimal player?
Thx Tatoosh
Hi there,
Thx Tatoosh
same question!
Native playlists can be found at ‘/data/playlists.’
ok but somehow, i can’t have access to this root when the rpi is plugged.
All i have access to : usb, storage , and nas folders.
Sorry but i’m a real noob in linux stuff
Have a read about ‘ssh’, and then enable ssh as described here.
Thanks! Unfortunately this takes really too much handling…
Wouldn’t it be simpler to have a plugin for that? Volumio is a really awesome solution at home, but I’d love to be able to transfer my playlist to my Fiio Flac player back and forth to have a perfect image of both
Sure it would, but someone needs to write it Any offers?
Not offering, but while you’re at it, maybe include back and forth iTunes playlist conversion
Should be do-able imho.
You can backup your playlists with the “Backup & Restore” Plugin. It is alreadyin Volumio Plugin repository.
