How can I expand the size of the used space on an SD card in Volume for Odroid C1+?
I would like to add some software but the space is limited.
as you probably mean the root partition, you need to do that offline.
I use gparted on my linux machine.
Good thing in Volumio 2: it does that automatically on first boot.
Gé
try this as a script (call it “resize.sh”), run it as root, you might want to backup first
/#!/bin/bash
fdisk_first() {
p2_start=`fdisk -l /dev/mmcblk0 | grep mmcblk0p2 | awk '{print $2}'`
echo "Found the start point of mmcblk0p2: $p2_start"
fdisk /dev/mmcblk0 << __EOF__ >> /dev/null
d
2
n
p
2
$p2_start
p
w
__EOF__
sync
touch /root/.resize
echo "Ok, Partition resized, please reboot now"
echo "Once the reboot is completed please run this script again"
resize_fs() {
echo "Activating the new size"
resize2fs /dev/mmcblk0p2 >> /dev/null
echo "Done!"
echo "Enjoy your new space!"
rm -rf /root/.resize
if [ -f /root/.resize ]; then
resize_fs
else
fdisk_first
fi
Thanks Gé!
Initially the script didn’t work, probably because I had been trying a few things before. But when I tried it on a fresh Volume install it worked!
I see that you are running Volume 2 on the Odroid C1+. I would like to try this but don’t know how. I could only find a Beta image for the RPi and in the Build section I did not find an option for the C1+.
Any suggestions would be much appreciated.
Thanks, Guus
Hi Guus,
it’s on my TODO list for the weekend. The C1+ has the same level of development as the PI.
I need to check with Michelangelo if he can generate the image and upload it to the repo for me.
There are a few more members that asked for it.
Gé
