I am using volumio-0.979-2016-08-20-pi on raspberry pi 2b
I followed Increase the partition size guides at faq but cant success.
after deleting and rebooting my system cant boot.
is there any differences on volumio2 to expand filesystem to whole sd
You both are correct, but I experienced the same problem. The partition “overlay” is not used when installing packages, at least not at default. I’ve run into the same problem trying to install all MPD dependencies to cook a new version. Haven’t tried to resize partitions just yet, because I don’t want to brick my installation.
Works like a charm! I was able to recompile mpd (had to install 1.5Gb of packages), so the test is successful.
But the main thread was about being able to install packages, this solves it!
