I’m new here (so if I’m not following the right procedure I’m sorry).
I have Volumio running on a Rasberry pi 4 + Allo Boss dac.
The system is running very well.
Recently I installed a plugin for streaming from Youtube.
This also works fine, allthough when I’m not ussing the Youtube streaming Volumio still has every 5 seconds a query to Youtube.
When I disable the plugin this continues.
Even when I remove the plugin the queries continues.
When I restart Volumio the queries to Youtube are over.
Does someone have the same problem and have a solution to this behavior?
Thanks!!
Dear Patrick,
Thank you for your reaction.
I can re-install the plug-in and let you see a log. But before I do I want to confirm I show you the right logs.
From the logs of my pi-hole I see that Volumio has every 5 seconds a query to YouTube. Do you want a printscreen of this ?
Dear Patrick,
I have 2 print screens made with pi-hole:
one when playing YouTube Music.
Then you see every 5 seconds a query. On 16:26:04 you see a different query. Maybe for a login.?
one after removing the YouTube Music plugin.
On 16:27h I removed the plugin. You see that the queries continues after this moment.
In between I noticed that I can log into YouTube Music with a code from the plugin.
If I log in then there are less queries (, but also less posibilities to stream music).
Maybe this relates to the question.?
Thanks. Hein
(I got an error when uploading the printscreens. So I will try this in a seperate message.)
