ethtool network tweaks
Useful or useless
Seeing that most everyone will use Volumio over a network to access much and/or Internet radio would it be useful to add some network tweaks in order to help this aspect operate at full efficiency?
Or Maybe Not?
Yawn
42 views and not a single response.
FYI, pro or con you need to make your opinion be known, including any tests results from trying different things.
This is a great piece of software SPEAK UP and be active, dont let this thing die like so many other Linux based softwares.
what do you mean with network tweaks?
I might misunderstand but ethtool allows users to adjust the settings on their computers Ethernet card
thegeekstuff.com/2010/10/ethtool-command/
Well apparently Volumio does use a ethernet tweek
I changed the ntu value of 1500 to 9000 to allow Jumbo frames
ifconfig eth0 mtu 9000
More Info here:
Linux Configure Jumbo Frames to Boost Network Performance / Throughput
Jumbo frames can reduce server overhead such as a big decrease in CPU usage when transferring larger file. Also you should see some increase in network throughput.
cyberciti.biz/faq/rhel-cento … iguration/
