Hi, apologies if this has already been solved, but I have failed to find a solution.
I have a pi Zero W with a very nice ES90382qm based DAC connected via i2s. With the standard Raspbian OS this works really well - I use mpd, but have also had success with kodi.
Over the past few years I have been trying to get this combination to work with volumio but have had no success. I choose audiophonics es9028q2m DAC but when volumio boots I get an horrendous noise which is repeated when I attempt to play any music. I have tried various other DACs but no joy. Looking at dmesg I see these errors:
[ 32.225404] snd-rpi-i-sabre-q2m soc:sound: snd_soc_register_card() failed: -517
[ 32.382748] snd-rpi-i-sabre-q2m soc:sound: snd_soc_register_card() failed: -517
[ 35.519156] snd-rpi-i-sabre-q2m soc:sound: snd_soc_register_card() failed: -517
[ 36.094193] snd-rpi-i-sabre-q2m soc:sound: snd_soc_register_card() failed: -517
[ 43.828161] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 43.828206] snd-rpi-i-sabre-q2m soc:sound: Audiophonics Device ID : FFFFFF87
[ 43.829493] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 43.829537] snd-rpi-i-sabre-q2m soc:sound: Audiophonics API revision : FFFFFF87
[ 56.297266] i-sabre-codec-i2c 1-0048: ASoC: error at snd_soc_component_update_bits on i-sabre-codec-i2c.1-0048: -121
[ 56.331117] i-sabre-codec-i2c 1-0048: ASoC: error at snd_soc_component_update_bits on i-sabre-codec-i2c.1-0048: -121
[ 56.365694] i-sabre-codec-i2c 1-0048: ASoC: error at snd_soc_component_update_bits on i-sabre-codec-i2c.1-0048: -121
[ 126.443038] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 126.443498] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 126.443897] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 126.445529] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 145.393209] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 145.397334] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 145.397851] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 146.413284] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 146.415090] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 146.419969] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 148.383295] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 148.384524] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 148.399191] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 152.818369] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 152.826345] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 152.826819] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 176.038256] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 176.038690] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 176.039090] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 195.844529] i-sabre-codec-i2c 1-0048: ASoC: error at snd_soc_component_update_bits on i-sabre-codec-i2c.1-0048: -121
[ 201.095825] i-sabre-codec-i2c 1-0048: ASoC: error at snd_soc_component_update_bits on i-sabre-codec-i2c.1-0048: -121
[ 435.383481] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 435.383956] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
[ 435.384441] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048 -121
[ 435.395948] i-sabre-codec-i2c 1-0048: ASoC: error at soc_component_read_no_lock on i-sabre-codec-i2c.1-0048: -121
any ideas what I need to get the DAC working on volumio>
cheers
