Error install volumio 2.041 on BBB
Hello
Here a DCHP client issue during install the 2.041 (or older 2.032) Volumio.
Here the log :
[FAILED] Failed to start LSB: IPv4 DHCP client with IPv4LL support. See 'systemctl status dhcpcd.service' for details. [ OK ] Started Permit User Sessions. [FAILED] Failed to start dhcpd.service. See 'systemctl status dhcpd.service' for details.
[code]root@volumio:~# systemctl status dhcpcd.service
● dhcpcd.service - LSB: IPv4 DHCP client with IPv4LL support
Loaded: loaded (/etc/init.d/dhcpcd)
Active: failed (Result: exit-code) since Sun 2016-12-11 22:13:04 UTC; 19s ago
Process: 484 ExecStart=/etc/init.d/dhcpcd start (code=exited, status=6)
Dec 11 22:13:02 volumio dhcpcd[484]: Not running dhcpcd because there is al…d!
Dec 11 22:13:02 volumio dhcpcd[484]: /var/run/dhcpcd-eth0.pid … failed!
Dec 11 22:13:04 volumio systemd[1]: dhcpcd.service: control process exited,…=6
Dec 11 22:13:04 volumio systemd[1]: Failed to start LSB: IPv4 DHCP client w…t.
Dec 11 22:13:04 volumio systemd[1]: Unit dhcpcd.service entered failed state.[/code]
Any ideas on this issue ?
I get the same error even with another SDcard.
Do I have to install IMG on eMMC ?
Don’t bother this error, its harmless
