Ciao
Ho Berryboot con installato Volumio. Come DAC ho un Allo Digione. Impostando I2SDAC su ON, e DAC Model = Allo DigiOne, mettendo in PLAY mi da errore: Error. Failed to open “Alsa” [Alsa]; Failed to open ALSA device “hw:1,0”: No such file or directory.
Ho controllato le soluzioni finora proposte ma senza successo. HELP ME !!!
you should use normal Volumio and not Berryboot, we can’t support what’s not official
OK. Thanks
@Pongo
Pls direct any Berryboot related question to specific Berryboot thread.
Indeed consider this setup as not officially supported hack as mentioned in original thread (please read all the spoiler).
However, I can try to help there (captured question there)
