Hi guys! I’ve been using volumio for a while now with no issues until now. I’m using a very simple low power system. Volumio is installed on a pi zero 2w connected to wifi. The audio is routed via the IQAudio Pi Digi Amp+. All of a sudden it stopped playing music and i keep getting the message “Error
Failed to open “alsa” (alsa); Failed to
open ALSA device “volumio”: No such
device” ive looked up the community for solutions and try plentiful, none worked. I assumed its the fault of the dac but then volumio startup tone is played crystal clear. Post that i keep getting the error. Then i installed the pluggin system info and got this error “Audio Hardware detection seems to
fail. Do not play music or equalizer while probing system and retry”
hi!
try the following : set output to headphone or hdmi and save.
now set your dac and save. Reboot
