Dear volumio group if you add a equalizer system in volumio music player then player sound more good . please think this features . thank you .
Balbuze has already created a plugin for volumio 2 that will add an equalizer.
Its currently still in development, but should be released very soon.
Thank you for reply . dear volumio 2 have an equlizer system ?
Dear when release volumio 2 ?
Dear new volumio realise 20/08/2016 but no equlizer added . can anyone tell me when this features added in volumio ?
A work is still in progress. It will be provided as a plugin. It will be more than a simple equalizer. I can’t tell you exactly when, but maybe before the end of september it should be ok…
Ok dear i am very happy your reply and i am waiting for this features .
Hi there. Now that I’ve got Volumio 2 and your Spotify Connect plug-in up and running, I’m looking to improve the sound on my tiny speakers (I’m too greedy!) Is there any update on the EQ plug-in? Thanks for your hard work! Treve
I am still now waitting for equalizer plug ins . i don’t know when i get it .
Good things come to those who wait!
But why is waiting for good things that should come to those who wait so hard?
Many volumio version releaseing some few month ago but when available equlizer system in volumio can anyone tell me ?
Dear michelangelo what i do this link ? how can i get equlizer plug ins ?
I think that plugin linked to by Michelangelo will eventually include an equaliser.
brutefir.zip this file now under testing no audio sound quality improve
@claudio1889
I know you are waiting for this feature for such a long time…
Brutefir plugin does what it what suppose to do since the begining : installing, setting and using brutefir in few clicks. It is done, once can use custom filter filter in 5 minutes !
The equalizer function is a add-on : why not using brutefir which is able to manage a equalizer ? It’s because I started to add this. But unfortunatly, I struggle to finish. And to be honnest I didn’t spend a lot of time on that point… I’m going to restart, but I think I would need some to write index.js …
Really sorry for this new delay …
Dear balbuze Brutefir plugin is not a equalizer plug ins ? if not then what is working of Brutefir plugin ?
Brutefir plugin is easy way to use brutefir in volumio2 to apply custom filter and thus doing DRC.
And brutefir can be used a equalizer. This part will be use in the plugin to provide what you are waiting for.
So yes the plugin will provide a equalizer, but not only !
As of now what is working :
installation, configuration, and use of custom filter (the plugin provide some filters to test).
What not works yet :
gain and phase equalizer
ok balbuze thank you for reply now i want to know how to install Brutefir plugin ? kindly tell me Brutefir plugin installing procedure ?
