Volumio Information
Volumio Version: 2.873-2021-02-19
Hardware: Raspberry PI 4
DAC: SMSL Sanskrit 10th
Hi, I was looking for an equalizer (software) that I can use. Using Volumio’s “Help” function, I came to this page:
[Plugin System Overview - Volumio Documentation ]
and in the third image I saw that there is a plugin called “Volumio Simple Equalizer”, but I can’t find it in my menu.
What could be the problem?
thank you
Yes i have the same problem. i cant find this plugin
dvo
April 12, 2021, 12:23pm
3
what version of volumio are you using?
this is one for 3.xx
Sure you are welcome to test BUT PLEASE do not post to report any bug/issue in BETA thread if you install a plugin.
You can post here for EQ as they are in test too…
Enable ssh
2 choices (both can be installed on the same system, but enable only the one you want to test.
Graphical 10 bands
wget https://github.com/balbuze/volumio-plugins/raw/alsa_modular/plugins/audio_interface/volsimpleequal10/volsimpleequal10.zip
mkdir vols
miniunzip volsimpleequal10.zip -d ./vols
cd vols
volumio plugin in…
and here the rest :
After a long wait, I uploaded a new new plugin “Volumio Simple Equalizer”.
It provide a “one click” configuration (just enable the plugin) and you’ll get a 10 bands equalizer with preset.
This a beta version and may not work as expected
NOT compatible with Softvol !
May not work with kali reclocker (need some tweaks)
Feedbacks welcome !
Enjoy ! (if it works for you)
source : github.com/balbuze/volumio-plug … impleequal
file to download : github.com/balbuze/volumio-plu…
