Hi
According to manual it should possible use hardware control for volume in HifiBerry DAC+.
I have enabled hardware control from the Volumio GUI, but nothing seems to happen. I can not change volume either from Volumio GUI or DLNA client.
I found some other posts in this site regarding DAC+ and they pointed out that mpd.config must be set in a certain way. I have checked my mpd.config and it is according to instructions in those posts (Volumio GUI seems to set up everything )
Is there some steps I am missing in the setup?
I am running Volumio 1.55 on a Raspberry 2.
//lg
Never mind. Now it is working.
After fiddling around a couple of hours, it suddenly starded to work. I cant help others, because I dont know what change that did it…
Are you comfortable with ssh and the command line?
Anyway, connect via ssh and do the follow:
root@volumio:~# amixer
You should see something like this:
Simple mixer control 'DSP Program',0
Capabilities: enum
Items: 'FIR interpolation with de-emphasis' 'Low latency IIR with de-emphasis' 'High attenuation with de-emphasis' 'Fixed process flow' 'Ringing-less low latency FIR'
Item0: 'High attenuation with de-emphasis'
Simple mixer control 'Analogue',0
Capabilities: pvolume
Playback channels: Front Left - Front Right
Limits: Playback 0 - 1
Mono:
Front Left: Playback 0 [0%] [-6.00dB]
Front Right: Playback 0 [0%] [-6.00dB]
Simple mixer control 'Analogue Playback Boost',0
Capabilities: volume
Capture channels: Front Left - Front Right
Limits: 0 - 1
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Auto Mute',0
Capabilities: pswitch
Mono:
Front Left: Playback [on]
Front Right: Playback [on]
Simple mixer control 'Auto Mute Mono',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'Auto Mute Time Left',0
Capabilities: enum
Items: '21ms' '106ms' '213ms' '533ms' '1.07s' '2.13s' '5.33s' '10.66s'
Item0: '21ms'
Simple mixer control 'Auto Mute Time Right',0
Capabilities: enum
Item0: '21ms'
Simple mixer control 'Clock Missing Period',0
Capabilities: enum
Items: '1s' '2s' '3s' '4s' '5s' '6s' '7s' '8s'
Item0: '1s'
Simple mixer control 'Deemphasis',0
Mono: Playback [on]
Simple mixer control 'Digital',0
Capabilities: pvolume pswitch
Limits: Playback 0 - 255
Mono:
Front Left: Playback 189 [74%] [-9.00dB] [on]
Front Right: Playback 189 [74%] [-9.00dB] [on]
Simple mixer control 'Volume Ramp Down Emergency Rate',0
Capabilities: enum
Items: '1 sample/update' '2 samples/update' '4 samples/update' 'Immediate'
Item0: '1 sample/update'
Simple mixer control 'Volume Ramp Down Emergency Step',0
Capabilities: enum
Items: '4dB/step' '2dB/step' '1dB/step' '0.5dB/step'
Item0: '4dB/step'
Simple mixer control 'Volume Ramp Down Rate',0
Capabilities: enum
Simple mixer control 'Volume Ramp Down Step',0
Capabilities: enum
Item0: '1dB/step'
Simple mixer control 'Volume Ramp Up Rate',0
Capabilities: enum
Simple mixer control 'Volume Ramp Up Step',0
Capabilities: enum
Item0: '1dB/step'
Then check the mpd.conf which, in my case, needs the following setup:
[code]audio_output {
type "alsa"
name "Output"
device "hw:0,0"
mixer_control "Digital"
mixer_device "hw:0"
mixer_index "0"
dop "no"
[/code]
(Note the Digital, which is the correct setting, I think because of some updates I did).
