@volumio I have not tried the beta. But can you add a setting where we can disable the status-led on rpi? That’s easy enough via ssh, but it would be great with an option.
What is the advantage of doing it?
Can you provide the command to launch to make it ?
config.txt:
Disable the ACT LED.
dtparam=act_led_trigger=none
dtparam=act_led_activelow=off
Disable the PWR LED.
dtparam=pwr_led_trigger=none
dtparam=pwr_led_activelow=off/boot
Works even on an old Raspberry 2 B !
A better way is to edit userconfig.txt
volumio@volumio1:~$ cat /boot/config.txt
### DO NOT EDIT THIS FILE ###
