Hi.
Volumio does not start after a power failure.
It’s in emergency mode, but I can’t fix it according to the descriptions given there.
The machine is an x86 PC (HP t520), the system is on an SSD.
If I type “systemctl default” it goes back to the beginning “you are in emergency mode”.
The “systemctl reboot” command does not work and the “exit” command does not enter default mode either, emergency mode starts in the same way.
I get a “dpkg error” message after the “dpkg reconfigure” command.
Can anyone help me avoid having to reinstall the system?
Thnx
