Edit network mount (remove this mount)
It is unclear why so crooked made service mount that then I could not remove the network mount :blush: :blush: :blush:
So, if the mount fails, volumio hangs and does not remove the mount point …
404 Not Found
nginx/1.2.1
192.168.1.232/sources.php
:bulb:
I can not get into the menu Library, but even if we hit it, then remove the mount point is not possible.
At each site as advertising, so much joy, but this program really wet, and almost everything works through the *** :imp: :imp:
and the point of using the network of the program is lost, because after a bad mount, the program re-installation of the new
