Easy way to add green PWR LED
Hello - I would like to add a green LED to my Volumio instal on a PI 5 - I’d like the LED to simply illuminate when the PI is powered up and go off when shut down. Please can you tell me what code I will need to enter and if GPIO 17 is the best pin to use? cheers!
The easiest way is adding an overlay to /boot/userconfig.txt
like below, I use it on GPIO 16:
gpio=16=op,dh
Thanks but /boot/userconfig.txt results in ‘Permission denied’
Impossible,
What steps did you take?
Hi - I entered Volumio as the password and when presented with volumio@volumio : $ - after the $ I typed the script in your original reply
I didn’t give you a script??
you should do:
nano /boot/userconfig.txt
Add:
gpio=16=op,dh
Press:
ctrl + o => Enter => ctrl + x
Reboot
