I realize I´m pasting too much info here, but I´ll get the hang of it ![:wink: :wink:](/images/emoji/apple/wink.png?v=9)
This is from a clean start, without brutefir or volstereo2mono initilized. Then, enabling brutefir - seem ok…
volumio@oa5:/$ sudo journalctl -f
– Logs begin at Wed 2020-04-22 20:21:45 UTC. –
Apr 22 20:23:41 oa5 systemd[1288]: Starting Basic System.
Apr 22 20:23:41 oa5 systemd[1288]: Reached target Basic System.
Apr 22 20:23:41 oa5 systemd[1288]: Starting Default.
Apr 22 20:23:41 oa5 systemd[1288]: Reached target Default.
Apr 22 20:23:41 oa5 systemd[1288]: Startup finished in 32ms.
Apr 22 20:23:41 oa5 systemd[1]: Started User Manager for UID 1000.
Apr 22 20:23:41 oa5 sshd[1283]: lastlog_openseek: Couldn’t stat /var/log/lastlog: No such file or directory
Apr 22 20:23:58 oa5 sudo[1301]: volumio : TTY=pts/0 ; PWD=/ ; USER=root ; COMMAND=/bin/journalctl -f
Apr 22 20:23:58 oa5 sudo[1301]: pam_unix(sudo:session): session opened for user root by volumio(uid=0)
Apr 22 20:24:13 oa5 volumio[1060]: info: CoreCommandRouter::volumioGetState
Apr 22 20:24:13 oa5 volumio[1060]: info: CoreStateMachine::getState
Apr 22 20:24:13 oa5 volumio[1060]: info: CorePlayQueue::getTrack 0
Apr 22 20:24:13 oa5 sudo[1323]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Apr 22 20:24:13 oa5 sudo[1323]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 22 20:24:13 oa5 sudo[1323]: pam_unix(sudo:session): session closed for user root
Apr 22 20:24:15 oa5 sudo[1332]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
Apr 22 20:24:15 oa5 sudo[1332]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 22 20:24:15 oa5 sudo[1334]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Apr 22 20:24:15 oa5 sudo[1332]: pam_unix(sudo:session): session closed for user root
Apr 22 20:24:15 oa5 sudo[1334]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 22 20:24:15 oa5 sudo[1334]: pam_unix(sudo:session): session closed for user root
Apr 22 20:24:15 oa5 volumio[1060]: info: CoreCommandRouter::volumioGetVisibleSources
Apr 22 20:24:15 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: my_music , getDisabledSources
Apr 22 20:24:15 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
Apr 22 20:24:15 oa5 volumio[1060]: info: CoreCommandRouter::volumioGetState
Apr 22 20:24:15 oa5 volumio[1060]: info: CoreStateMachine::getState
Apr 22 20:24:15 oa5 volumio[1060]: info: CorePlayQueue::getTrack 0
Apr 22 20:24:15 oa5 sudo[1350]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Apr 22 20:24:15 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
Apr 22 20:24:15 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
Apr 22 20:24:15 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: wizard , getShowWizard
Apr 22 20:24:15 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: system , getShowWizard
Apr 22 20:24:15 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: system , getPrivacySettings
Apr 22 20:24:15 oa5 sudo[1350]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 22 20:24:15 oa5 sudo[1352]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Apr 22 20:24:15 oa5 sudo[1350]: pam_unix(sudo:session): session closed for user root
Apr 22 20:24:15 oa5 sudo[1352]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 22 20:24:15 oa5 volumio[1060]: info: Listing playlists
Apr 22 20:24:15 oa5 sudo[1352]: pam_unix(sudo:session): session closed for user root
Apr 22 20:24:17 oa5 volumio[1060]: info: CoreCommandRouter::volumioGetQueue
Apr 22 20:24:17 oa5 volumio[1060]: info: CoreStateMachine::getQueue
Apr 22 20:24:17 oa5 volumio[1060]: info: CorePlayQueue::getQueue
Apr 22 20:24:23 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioStatus
Apr 22 20:24:26 oa5 volumio[1060]: info: Enabling plugin brutefir
Apr 22 20:24:26 oa5 volumio[1060]: info: Loading plugin “brutefir”…
Apr 22 20:24:27 oa5 volumio[1060]: info: Applying required configuration parameters for plugin brutefir
Apr 22 20:24:27 oa5 volumio[1060]: info: PLUGIN START: brutefir
Apr 22 20:24:27 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
Apr 22 20:24:27 oa5 sudo[1381]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/modprobe snd_aloop index=7 pcm_substreams=2
Apr 22 20:24:27 oa5 sudo[1381]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 22 20:24:27 oa5 kernel: pcm512x 1-004c: No SCLK, using BCLK: -2
Apr 22 20:24:27 oa5 volumio[1060]: info: Done.
Apr 22 20:24:27 oa5 sudo[1381]: pam_unix(sudo:session): session closed for user root
Apr 22 20:24:27 oa5 volumio[1060]: info: snd_aloop loaded
Apr 22 20:24:27 oa5 volumio[1060]: AAAAAAAAAAAAAAAAAAAAAAAAAA-> 2 <-AAAAAAAAAAAAA
Apr 22 20:24:27 oa5 volumio[1060]: AAAAAAAAAAAAAAAAAAAAAAAAAA-> S16_LE S24_LE S32_LE <-AAAAAAAAAAAAA
Apr 22 20:24:27 oa5 volumio[1060]: AAAAAAAAAAAAAAAAAAAAAAAAAA-> 44100 48000 88200 96000 176400 192000 <-AAAAAAAAAAAAA
Apr 22 20:24:27 oa5 volumio[1060]: info: Auto set output format : -------> S32_LE
Apr 22 20:24:27 oa5 volumio[1060]: info: no delay needed
Apr 22 20:24:27 oa5 volumio[1060]: S16_LE
Apr 22 20:24:27 oa5 sudo[1396]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart brutefir.service
Apr 22 20:24:27 oa5 sudo[1396]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 22 20:24:27 oa5 systemd[1]: Starting brutefir Daemon…
Apr 22 20:24:27 oa5 systemd[1]: Started brutefir Daemon.
Apr 22 20:24:27 oa5 volumio[1060]: info: CoreCommandRouter::volumioGetState
Apr 22 20:24:27 oa5 volumio[1060]: info: CoreStateMachine::getState
Apr 22 20:24:27 oa5 volumio[1060]: info: CorePlayQueue::getTrack 0
Apr 22 20:24:27 oa5 sudo[1404]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Apr 22 20:24:27 oa5 volumio[1401]: BruteFIR v1.0m (November 2013) © Anders Torger
Apr 22 20:24:27 oa5 sudo[1404]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 22 20:24:27 oa5 volumio[1401]: Internal resolution is 64 bit floating point.
Apr 22 20:24:27 oa5 sudo[1404]: pam_unix(sudo:session): session closed for user root
Apr 22 20:24:27 oa5 volumio[1401]: Creating 4 FFTW plans of size 16384…finished.
Apr 22 20:24:27 oa5 sudo[1396]: pam_unix(sudo:session): session closed for user root
Apr 22 20:24:28 oa5 volumio[1401]: Loading 16 coefficient sets…finished.
Apr 22 20:24:28 oa5 volumio[1401]: Realtime priorities are min = 2, usermax = 1, mid = 3 and max = 4.
Apr 22 20:24:28 oa5 volumio[1401]: Warning: no support for clock cycle counter on this platform.
Apr 22 20:24:28 oa5 volumio[1401]: Timers for benchmarking may be unreliable.
Apr 22 20:24:28 oa5 volumio[1401]: Filters in process 0: 0 2
Apr 22 20:24:28 oa5 volumio[1401]: Filters in process 1: 1 3
Apr 22 20:24:28 oa5 kernel: pcm512x 1-004c: No SCLK, using BCLK: -2
Apr 22 20:24:28 oa5 volumio[1060]: info: Starting brutefir
Apr 22 20:24:28 oa5 sudo[1419]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl start brutefir.service
Apr 22 20:24:28 oa5 sudo[1419]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 22 20:24:28 oa5 systemd[1]: Started brutefir Daemon.
Apr 22 20:24:28 oa5 sudo[1419]: pam_unix(sudo:session): session closed for user root
Apr 22 20:24:28 oa5 volumio[1060]: info: Brutefir Daemon Started
Apr 22 20:24:28 oa5 volumio[1401]: Realtime priority 1 set for cli process (pid 1417)
Apr 22 20:24:28 oa5 volumio[1401]: Realtime priority 3 set for input process (pid 1402)
Apr 22 20:24:28 oa5 volumio[1401]: Realtime priority 4 set for filter process (pid 1416)
Apr 22 20:24:28 oa5 volumio[1401]: Realtime priority 4 set for filter process (pid 1415)
Apr 22 20:24:28 oa5 volumio[1401]: Realtime priority 3 set for output process (pid 1427)
Apr 22 20:24:28 oa5 volumio[1401]: Fixed I/O-delay is 16384 samples
Apr 22 20:24:28 oa5 volumio[1401]: Audio processing starts now
Apr 22 20:24:29 oa5 volumio[1060]: info: VolumeController::SetAlsaVolumemute
Apr 22 20:24:29 oa5 volumio[1060]: info: CoreStateMachine::pushState
Apr 22 20:24:29 oa5 volumio[1060]: info: CoreStateMachine::getState
Apr 22 20:24:29 oa5 volumio[1060]: info: CorePlayQueue::getTrack 0
Apr 22 20:24:29 oa5 volumio[1060]: info: CoreCommandRouter::volumioPushState
Apr 22 20:24:29 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
Apr 22 20:24:29 oa5 sudo[1431]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Apr 22 20:24:29 oa5 volumio[1060]: info: VolumeController::SetAlsaVolumeunmute
Apr 22 20:24:29 oa5 sudo[1431]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 22 20:24:29 oa5 sudo[1431]: pam_unix(sudo:session): session closed for user root
Apr 22 20:24:29 oa5 sudo[1441]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Apr 22 20:24:29 oa5 sudo[1441]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 22 20:24:29 oa5 sudo[1441]: pam_unix(sudo:session): session closed for user root
Apr 22 20:24:32 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: i2s_dacs , disableI2SDAC
Apr 22 20:24:32 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
Apr 22 20:24:32 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: alsa_controller , saveAlsaOptions
Apr 22 20:24:32 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: i2s_dacs , getI2sStatus
Apr 22 20:24:32 oa5 volumio[1060]: info: Output device has changed, restarting MPD
Apr 22 20:24:32 oa5 sudo[1450]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/chmod 777 /etc/mpd.conf
Apr 22 20:24:32 oa5 volumio[1060]: info: Output device has changed, restarting Shairport Sync
Apr 22 20:24:32 oa5 sudo[1450]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 22 20:24:32 oa5 sudo[1450]: pam_unix(sudo:session): session closed for user root
Apr 22 20:24:32 oa5 sudo[1453]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart mpd.service
Apr 22 20:24:32 oa5 sudo[1453]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 22 20:24:32 oa5 systemd[1]: Stopping Music Player Daemon…
Apr 22 20:24:32 oa5 volumio[1060]: info: Could not detect Primo: Error: Command failed: aplay -l | grep es90x8q2m-dac-dai-0
Apr 22 20:24:32 oa5 volumio[1060]: info: Device Loopback does not have any Mixer Control Available, setting a softvol device
Apr 22 20:24:33 oa5 systemd[1]: Starting Music Player Daemon…
Apr 22 20:24:33 oa5 volumio[1060]: info: CoreCommandRouter::volumioUpdateVolumeSettings
Apr 22 20:24:33 oa5 volumio[1060]: info: Updating Volume Controller Parameters: Device: Loopback Name: Mixer: Max Vol: 100 Vol Curve; logarithmic Vol Steps: 10
Apr 22 20:24:33 oa5 volumio[1060]: info: CoreCommandRouter::getUIConfigOnPlugin
Apr 22 20:24:33 oa5 volumio[1060]: info: CoreStateMachine::pushState
Apr 22 20:24:33 oa5 volumio[1060]: info: CoreStateMachine::getState
Apr 22 20:24:33 oa5 volumio[1060]: info: CorePlayQueue::getTrack 0
Apr 22 20:24:33 oa5 volumio[1060]: info: CoreCommandRouter::volumioPushState
Apr 22 20:24:33 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
Apr 22 20:24:33 oa5 sudo[1477]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Apr 22 20:24:33 oa5 volumio[1060]: info: MPD Permissions set
Apr 22 20:24:33 oa5 sudo[1477]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 22 20:24:33 oa5 sudo[1477]: pam_unix(sudo:session): session closed for user root
Apr 22 20:24:33 oa5 sudo[1484]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/dtoverlay -l
Apr 22 20:24:33 oa5 sudo[1484]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 22 20:24:33 oa5 sudo[1484]: pam_unix(sudo:session): session closed for user root
Apr 22 20:24:33 oa5 volumio[1060]: info: No Overlays Loaded
Apr 22 20:24:33 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
Apr 22 20:24:33 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: i2s_dacs , getI2sOptions
Apr 22 20:24:33 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
Apr 22 20:24:33 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: i2s_dacs , getI2sStatus
Apr 22 20:24:33 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
Apr 22 20:24:33 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: system , getAdvancedSettingsStatus
Apr 22 20:24:33 oa5 volumio[1060]: info: Starting Shairport Sync
Apr 22 20:24:33 oa5 sudo[1503]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart shairport-sync
Apr 22 20:24:33 oa5 sudo[1503]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 22 20:24:33 oa5 systemd[1]: Stopping Shairport Sync - AirPlay Audio Receiver…
Apr 22 20:24:33 oa5 systemd[1]: Starting Shairport Sync - AirPlay Audio Receiver…
Apr 22 20:24:33 oa5 systemd[1]: Started Shairport Sync - AirPlay Audio Receiver.
Apr 22 20:24:33 oa5 sudo[1503]: pam_unix(sudo:session): session closed for user root
Apr 22 20:24:33 oa5 sudo[1512]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl start spop.service
Apr 22 20:24:33 oa5 sudo[1512]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 22 20:24:33 oa5 volumio[1060]: info: Shairport-Sync Started
Apr 22 20:24:33 oa5 systemd[1]: Configuration file /lib/systemd/system/spop.service is marked executable. Please remove executable permission bits. Proceeding anyway.
Apr 22 20:24:33 oa5 systemd[1]: Configuration file /lib/systemd/system/spop.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
Apr 22 20:24:33 oa5 systemd[1]: Starting Spotify Daemon…
Apr 22 20:24:33 oa5 systemd[1]: Started Spotify Daemon.
Apr 22 20:24:33 oa5 sudo[1512]: pam_unix(sudo:session): session closed for user root
Apr 22 20:24:33 oa5 systemd[1]: Started Music Player Daemon.
Apr 22 20:24:33 oa5 sudo[1453]: pam_unix(sudo:session): session closed for user root
Apr 22 20:24:33 oa5 volumio[1060]: info: SpopD Daemon Started
Apr 22 20:24:33 oa5 volumio[1531]: 2020-04-22 20:24:33 [SPTF] 20:24:33.886 I [ap:1752] Connecting to AP ap.spotify.com:4070
Apr 22 20:24:33 oa5 volumio[1531]: 2020-04-22 20:24:33 [SPTF] 20:24:33.961 I [ap:1226] Connected to AP: 35.190.243.13:4070
Apr 22 20:24:34 oa5 volumio[1531]: 2020-04-22 20:24:34 [SPTF] 20:24:34.525 I [offline-mgr:2082] Storage has been cleaned
Apr 22 20:24:35 oa5 volumio[1531]: 2020-04-22 20:24:35 [SPTF] 20:24:35.517 I [offline-mgr:2030] 0 files are locked. 0 images are locked
Apr 22 20:24:35 oa5 volumio[1531]: 2020-04-22 20:24:35 [SPTF] 20:24:35.519 I [offline-mgr:2056] 0 files unlocked. 0 images unlocked
Apr 22 20:24:35 oa5 volumio[1060]: info: CoreCommandRouter::volumioRetrieveVolumeLevels
Apr 22 20:24:35 oa5 volumio[1060]: info: CoreStateMachine::getcurrentVolume
Apr 22 20:24:35 oa5 volumio[1060]: info: CoreCommandRouter::volumioRetrievevolume
Apr 22 20:24:35 oa5 volumio[1060]: info: CoreStateMachine::pushState
Apr 22 20:24:35 oa5 volumio[1060]: info: CoreStateMachine::getState
Apr 22 20:24:35 oa5 volumio[1060]: info: CorePlayQueue::getTrack 0
Apr 22 20:24:35 oa5 volumio[1060]: info: CoreCommandRouter::volumioPushState
Apr 22 20:24:35 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
Apr 22 20:24:35 oa5 sudo[1547]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Apr 22 20:24:35 oa5 sudo[1547]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 22 20:24:35 oa5 sudo[1547]: pam_unix(sudo:session): session closed for user root
Apr 22 20:24:38 oa5 volumio[1060]: info: Connecting to daemon
Apr 22 20:24:38 oa5 volumio[1060]: info: CoreCommandRouter::volumioAddToBrowseSources[object Object]
Apr 22 20:24:38 oa5 volumio[1060]: info: [1587587078638] CoreMusicLibrary::Adding element Spotify
Apr 22 20:24:38 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: my_music , getDisabledSources
Apr 22 20:24:38 oa5 volumio[1060]: info: FIRST BRANCH
Apr 22 20:24:38 oa5 volumio[1060]: info: An error occurred while listing Spotify featured playlists WebapiError: Unauthorized
Apr 22 20:24:38 oa5 volumio[1060]: info: An error occurred while listing Spotify new albums WebapiError: Unauthorized
Apr 22 20:24:38 oa5 volumio[1060]: info: An error occurred while listing Spotify categories WebapiError: Unauthorized
Apr 22 20:24:38 oa5 volumio[1060]: info: New Spotify access token = BQCA1CZVvQ6hvleL53uhx990prqTuERsZEKAjjK26vH0kwyHgdKtZY4qP967ftL-2SFg-PEA51Di90JdhPJ5UPCGCELHjstNzWOhHi0ma2x-7dHn8xit8VU2krwnq7eDJb1FWMytuIRUG9p4DzZ-XhEuKmU8DwKd5ZHjRy8gilTaJchKXVu8u3x6r4o
Apr 22 20:24:38 oa5 volumio[1060]: info: Spotify credentials grant success - running version from March 24, 2019
Apr 22 20:24:39 oa5 volumio[1060]: { device: ‘1’,
Apr 22 20:24:39 oa5 volumio[1060]: name: ‘IQaudIO Pi-DigiAMP+’,
Apr 22 20:24:39 oa5 volumio[1060]: mixer: ‘Analogue’,
Apr 22 20:24:39 oa5 volumio[1060]: mixertype: ‘Hardware’,
Apr 22 20:24:39 oa5 volumio[1060]: maxvolume: ‘100’,
Apr 22 20:24:39 oa5 volumio[1060]: volumecurve: ‘logarithmic’,
Apr 22 20:24:39 oa5 volumio[1060]: volumestart: ‘disabled’,
Apr 22 20:24:39 oa5 volumio[1060]: volumesteps: ‘10’,
Apr 22 20:24:39 oa5 volumio[1060]: softvolumenumber: ‘undefined’ }
Apr 22 20:24:39 oa5 volumio[1060]: info: CoreCommandRouter::volumioUpdateVolumeSettings
Apr 22 20:24:39 oa5 volumio[1060]: info: Updating Volume Controller Parameters: Device: 1 Name: IQaudIO Pi-DigiAMP+ Mixer: Analogue Max Vol: 100 Vol Curve; logarithmic Vol Steps: 10
Apr 22 20:24:39 oa5 volumio[1060]: info: VolumeController:: Volume=100 Mute =false
Apr 22 20:24:39 oa5 volumio[1060]: info: CoreStateMachine::pushState
Apr 22 20:24:39 oa5 volumio[1060]: info: CoreStateMachine::getState
Apr 22 20:24:39 oa5 volumio[1060]: info: CorePlayQueue::getTrack 0
Apr 22 20:24:39 oa5 volumio[1060]: info: CoreCommandRouter::volumioPushState
Apr 22 20:24:39 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
Apr 22 20:24:39 oa5 sudo[1558]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Apr 22 20:24:39 oa5 sudo[1558]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 22 20:24:39 oa5 sudo[1558]: pam_unix(sudo:session): session closed for user root
Apr 22 20:24:44 oa5 volumio[1060]: info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
